Installation & Licensing
Inventor Suit 2009 Installation Issue
11 REPLIES 11
Message 1 of 12
maulik
464 Views, 11 Replies
Yesterday when i logged on my pc and turned on AutoCAD i got an error message saying This version of AutoCAD is not installed correctly and some features may not run correctly. You should reinstall AutoCAD immediately to make sure all features are running correctly" Screen shot is attached.
So to install it correctly, i uninstalled AutoCAD and tried to install it agian, it failed and i was unable to install it. At this time Inventor was working prooperly. So i tried to uninstall the entire Inventor Suit and tried to install it again. Now I was unable to install Inventor !
So i ended up installing all the softwares in the package seperately and I was able to install autocad, vault, design review but not inventor. I tried to use the Autocad that I just installed, and i see the same error message that i was getting yesterday morning.
At the end, i ended up uninstalling Inventor which was working properly and now I am not able to install it again, and also autocad is not working now!
Any idea how should i proceed now ?
11 REPLIES 11
Message 2 of 12
TravisNave
in reply to: maulik
If your OS is Windows 7, then your product is not supported on this platform.  Only 2010 products and later are supported on Windows 7.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 12
maulik
in reply to: TravisNave
Well I understand that Windows 7 is not supported but I have been using it since past 1 year ! All of a sudden something happened and I cannot use it.
Message 4 of 12
TravisNave
in reply to: maulik
I guess consider yourself lucky that you were able to get it to work for that long!  Smiley Very Happy
Maybe try a repair install or a system restore to when it worked?
Autodesk Forums:
Message 5 of 12
maulik
Tried everything possible. Uninstalled the entire Inventor Suit 3 times including the registry files. Still when I install i get the same error. Smiley Sad
The next thing I am gonna do is formate my pc, install Win 7 all over again and try to install the Inventor Suit then ! I hope it works then. Its still working on other two pc's in my office.
Message 6 of 12
TravisNave
in reply to: maulik
Have you considered Windows XP mode for your Windows 7?  You can download the virtual machine from Microsoft.  It is free for Windows 7 users.  It will allow you to run a Windows XP VM on your Windows 7 so that your older products can be installed.  Alternately, this product is supported on Windows Vista, but recommending you install Vista would be worse than anything I could ever do.
Autodesk Forums:
Message 7 of 12
maulik
Well, that would be a good idea ! But will I be able to connect to all shared drivers which are on the server ?
I can still give it  try tomorrow !
Message 8 of 12
TravisNave
in reply to: maulik
Yes, you certainly will.  It's like having a second computer on the network from within your Windows 7.
Autodesk Forums:
Message 9 of 12
maulik
in reply to: maulik
Update ! I just installed the Win xp virtual machine, installed Inventor Suit, it works ! But its too too slow. I have got here a i7 processor with 8 Gb ram.Its only good to print drawing and for nothing else.
I think the best chanace now I have is formate my entire pc and install it all over again becuase i know for fact it works on Win7 as its working on 2 more pc's in my office.
Message 10 of 12
TravisNave
in reply to: maulik
Yep, you might have to.  Have you tried an attempt at System Restore yet and choosing a date back when it worked?
Autodesk Forums:
Message 11 of 12
maulik
Due to some reason, i never had system restored anytime ! so unfortunately that option is no longer an option.
Message 12 of 12
TravisNave
in reply to: maulik
That's unfortunate.  Hopefully you'll have luck with a refresh of your OS.  Good luck!
Autodesk Forums:
Administrator Productivity
