Installation & Licensing
Inventor Publisher 2013 - Instant crash
7 REPLIES 7
Message 1 of 8
JakobAlm
1954 Views, 7 Replies
Hi!
My PC specs:
AMD Phenom X2 3.0 GHz
4 GB RAM
ATI Radeon HD6700
Windows 7 Ultimate
Whenever I try to start up Publisher 2013, I get the message "Autodesk Inventor Publisher has stopped working".
When I view the problem details I can see this problem signature.
Problem signature:
Problem Event Name: APPCRASH
Application Name: Inventor Publisher.exe
Application Version: 5.0.0.106
Application Timestamp: 4f3db7ba
Fault Module Name: mscoreei.dll
Fault Module Version: 4.0.30319.1
Fault Module Timestamp: 4ba21c38
Exception Code: c0000005
Exception Offset: 00000000000100c7
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1053
Additional Information 1: e37a
Additional Information 2: e37a1fbbe4619eb843146e8792dcfce2
Additional Information 3: be1d
Additional Information 4: be1d2703244347793cad701129a486c3
I located the source of the "mscoreei.dll" file, and it was connected to the .NET Framework 4. After reinstalling the whole framework, I tried to start it up once again. This time I got the same error, except that the Fault Module Name had changed to "PavSHook64.dll". It seems to be either "mscoreei.dll" or "PavSHook64.dll" that causes the error, yet I have no idea how to fix it.
I also get the exact same error whenever I try to launch Inventor Fusion 2013
Side note: I'm using the Student Version of the program. Also, these two programs are the only ones affected by this issue. Inventor 2013, AutoCAD 2012 and ShowCase 2012 work just fine.
Tried solutions:
- Reinstalling Autodesk Inventor Publisher 2013 (5 times to be exact)
- Reinstalling .NET Framework 4
- Reinstalling Autodesk Fusion
- Installing all available Windows 7 updates
- Virus scan and clean
- Malware, spyware scan and clean
7 REPLIES 7
Message 2 of 8
TadB
in reply to: JakobAlm
I am having a similar problem, except it's with Autocad 2013. Everytime I start the program I get this report. The program doesn't open, crashes during loading.
Application Name: acad.exe
Application Version: 25.0.55.0
Application Timestamp: 4f309abd
Fault Module Name: StackHash_01af
Fault Module Version: 6.1.7601.17725
Fault Module Timestamp: 4ec4aa8e
Exception Code: c0000374
Exception Offset: 00000000000c40f2
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 01af
Additional Information 2: 01af3e81258217071a2395ce7e9fc04a
Additional Information 3: e136
Additional Information 4: e1367d4379041c85bc20c78588f26171
Can't figure out the reason why.
Message 3 of 8
JakobAlm
I've done a complete format of both my drives today including a fresh install of W7 in hopes of fixing the issue. Currently downloading Inv. Publisher 2013 to try it.
Message 4 of 8
Do let us know how it goes with your clean reinstall of the product and the OS.
Are you running the product as an administrator for the first time after the install ?
Can you also try turning off UAC in your Windows 7  and see whether it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 5 of 8
JakobAlm
Hi! The problem did actually get solved with the clean OS install. I fired up Publisher 2013 late last night and it worked like a charm.
To answer your questions, I always run programs as an administrator and I tried turning UAC off. My guess is that my PC was missing some system files due to malware of some kind.
Message 6 of 8
upeo3
Hai!
For MEP 2103 it starts, when I used a Reset button on Profile.
The solution was easy - go to the Start Programm and in MEP folder press  Reset Settings to Default or  ("C:\Program Files\Autodesk\AutoCAD 2013\AdMigrator.exe" /reset /product "MEP" /language "en-US").
Have a nice day with AutoCad.
engineer Uldis
Latvia
Message 7 of 8
Stuie89
Hi, i have done a complete format and recovery of my laptop but still have the same problem. When double clicking publisher 2013 i get the error message publisher has stopped working. I now have the pavhooks64.dll in event viewer. i'm out of ideas now. Anyone help? I tried publisher 2012 yesterday and i get the message catalyst has stopped working and the startup screen of publisher hangs on the desktop. Please anyone help i'm pulling my hair out now!
Message 8 of 8
sheilon
in reply to: Stuie89
I have a very similar issue.
Installed Publisher 2013 R1 (64bit). Installation went well, however, when i try to start I can see in the background the
Windows Error Reporting draining resources and Publisher "disapears". Essentially it crashes and burns without any warnings, notices, etc. Tryin to troubleshoot I installed Publisher 2012 and got the exact same behavior.
(Windows 8.1, 8GB RAM)
Any help?
Administrator Productivity
