Here at our company we updated to the 2012 versions of Autodesk Inventor, AutoCAD mechanical, AutoCAD Electrical and Autodesk Vault back around memorial day. Since then we have noticed that an Inventor Professional License is being taken up by a user who is using AutoCAD Mechanical and/or AutoCAD Electrical. Can some one please explain to me how and why this is happening and what do to do to fix it. Any help would be appreciated I have tried everything I can think of, so now I am stuck.
Thank you.
Solved by anil_choudhary. Go to Solution.
Is this a network license? Did you install his Mechanical from the professional suite serial number? Electrical only pulls electrical, so something else is going on, I am sure.
What you might try in lieu of reinstallation (assuming this is network licensed) is create an adskflex.opt options file that excludes this user from accessing a professional license, thus pulling only a suite license. This should work, unless of course this user actually needs access to the professional license.
See the link in my signature for everything you need to know about the options file.
can you post any of the log files?
DarrenP
Hi
We would require the following information to understand the issue better.
If you would like to send this information confidentially, I will send you a separate private message please attach them in reply.
The cascading sequence for Autodesk 2012 products http://usa.autodesk.com/getdoc/id=TS16981643.
You may also want to Rename the CascadeInfo.cas file.
• Navigate to the following folder:
Windows XP > C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm
Windows Vista > C:\ProgramData\Autodesk\Adlm
• Rename the CascadeInfo.cas file to OLD_CascadeInfo.cas-backup OR move it to desktop
Launch Autodesk product and it will create cascadeinfo.cas form the new license file.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
yes could you please send me a private msg and I will copy the info for you
You can PM him by clicking here.
We reorganized license file. Put Individual Autodesk product license first and suite license at the bottom. It worked for the customer. Please check the article below for more information.
