Hi all,
First, I downloaded and installed Inventor 2015. Since I had some problems with using it I decided to reinstall it. The problem was that Inventor after opening froze. Inventor was not unresponsive but the canvas was white and nothing happened. I was able to use Inventor only once.
After uninstalling Inventor, I wanted install it again but Inventor is an inactive choice now (see the attachment). It says something about the language pack being already installed and I have been cleaning all related folders whole day and I cannot fix it.
Any ideas?
Solved by DannyHubbard. Go to Solution.
You should be able to use the Microsoft Fix It utility to uninstall the language pack.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Danny
The other thing you could try is running the following from a Command Prompt in Windows, then choose Yes to uninstall the product.
MsiExec.exe /X{7F4DD591-1964-0001-1033-7107D70F3DB4}
Danny
Krzysztof,
The best thing is to use the Microsoft Fix it utility mentioned previously.
I prefer to use the optioin to Let me select the fixes, then choose Uninstalling and look for an Autodesk Inventor 2015 <language> Language Pack entry and choose Next to remove the entry.
Danny
Danny,
It was not on the list provided by Microsoft Fix it so I chose 'not listed' and used {7F4DD591-1964-0001-1033-
7107D70F3DB4} (i.e. what you sent me before). It solved the problem.
Thank you very much!
Krzysztof
