Hi, I've been trying to install the student version of Inventor 2015, but everytime I run the setup, it says the installation has failed.
The installation log is attached. Thanks for the help 🙂
Solved by Suzukykawazaky69. Go to Solution.
How do you modify the setup.ini? I think I'm having the same problem that you had
Hello. I am guessing failures on Microsoft C++ and or NET were your issues. Uninstall them first usually alleviates blocks, or you can comment them out in the ini file, certainly.
Thank you for taking part in our community!
