I have successfully installed Inventor 2014 the student version however when I start it an error pops up. I have attached the image to this post.
Can someone please help me get rid of this error?
Solved by jeffrey.sin. Go to Solution.
Hi Aliyy,
Are you running Inventor 2014 on Windows 8 OS? For these errors, installing the service packs usually resolves the issue. Can you check out this Autodesk Solution and try out the suggestions there?
Inventor 2014 unexpectedly exits on startup on Windows 8.1
And here's where you can find all available Service Packs for Inventor:
