Installation & Licensing
Inventor 2014 Won't install
11 REPLIES 11
Message 1 of 12
3376 Views, 11 Replies
Hi all,
when I try to install inventor 2014 from the student free downloads, I get an error message reading
Error 1308. Source File not found: C:/Autodesk/WI/Autodesk Inventor 2014/x64/inventor/Program Files/Autodesk/Inventor 2014/Bin/Mb.dll. Verify that the file exists and you can access it.
I then searched manually for the file. I found all the other Mb files but not the one I was searching for. I've gone through the process multiple times and download new inventor downloads.
How do I solve this problem? Do I need to get a copy of the file?
11 REPLIES 11
Message 2 of 12
TravisNave
Try redownloading it instead from the virtual assistant:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Autodesk Forums:
Message 3 of 12
in reply to: TravisNave
I followed the instructions and downloaded Part 1 from the virtual assistant. When I select the destination folder, I get an error message saying
Product download consists of multiple files. At least one file is missing or has not been downloaded yet
Anything else I can try?
Message 4 of 12
dembkod
danbrowne5,
Hello. Part 1 is just part one. You need all parts first. Download them all and see if it helps.
Thank you for taking part in our community!
David Dembkoski
Message 5 of 12
in reply to: dembkod
Problem solved!
Thanks for all your help!
Message 6 of 12
Hi there,
Sorry for not being able to understand fully.  But I also have the same problem, except, Travis, when i click on that Link, it just takes me to download AutoCad?
If you would be able to do a step by step guide here, i would be really greatful.  Currently got a Project due for next week and it's just not working! 😞
             Ryan.
Message 7 of 12
Hello!
I'm trying to set up Inventor 2014 Toshiba Laptop but I got a pop box after a while of appearing the Inventor installer. I tried EVERYTHING of what it says, but I don't know. I almost crash up my computer and I feel so up set of not knowing what to do. PLEAAAAAAASE HELP!
Message 8 of 12
http://knowledge.autodesk.com/support/inventor-products/downloads#?sort=score
I believe this is the link that you are looking for.
Message 9 of 12
I have problems with the installation of Inventor on 2014 on my pc. I had already downloaded it then I reformatted my computer. Now, when I install it
again, I receive error messages. Could you help me please?
Message 10 of 12
camilo.lemos
Hi @Anonymous  and welcome to the Autodesk Community!
Please, disable your firewall and anti-virus programs and download the software from our Virtual Agent linked here (click on Download Links, choose product and version).
I hope this helps!
Camilo Lemos
Message 11 of 12
in reply to: camilo.lemos
Thank you, it's ok for Inventor 2014. Now, To install Autocad 2014, I always have the serial number but I lost the product key. Could you help me please ?
Message 12 of 12
camilo.lemos
Sure thing!
Product Keys for 2014 product are publicly available here.
Camilo Lemos
Administrator Productivity
