How do I fix error #0xc0000142 for Inventor LT Suite 2014
Solved by TravisNave. Go to Solution.
Did you install SP1?
Try getting the appropriate version here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322615&linkID=14002999
Good Luck!
The link worked ... had to be patient downloaing because windows explorer was unstable.
I followed the link and tried to install SP1 for Inventor LT 2014 after having gotten the 0xc0000142 error on windows 8 and it is telling me that the SP1 patch is not a valid patch.
I am running a Lenovo IdeaPad with Windows 8 64 bit.
I have already installed LT2014 and transferred the license using the license transfer utility successfully.
Any idea why I'd be having this problem?
Thanks!
Try downloading one of the two service packs from this link:
http://knowledge.autodesk.com/support/inventor-products
I had the same problem and e-mailed support. They originally told me to download the first link "Update 3 for Inventor 2014 Service Pack 1" but I only received another error. Since I was on a bit of a time crunch, I did some searching of my own and found the link above. I had to download the second link "Autodesk Inventor 2014 Service Pack 1" and I was able to launch Inventor after that. I hope one of those downloads will work for you.
