Installation & Licensing
Active Member
roblawarre
Message 1 of 11 (3,282 Views)
Inventor 2014 Error 0xC0000142 on Windows 8
3282 Views, 10 Replies
12-17-2013 08:02 AM
How do I fix error #0xc0000142 for Inventor LT Suite 2014
TravisNave
Message 2 of 11 (3,272 Views)
Re: Inventor 2014 Error 0xC0000142 on Windows 8
12-17-2013 09:11 AM in reply to: roblawarre
Did you install SP1?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
roblawarre
Message 3 of 11 (3,263 Views)
12-17-2013 11:34 AM in reply to: TravisNave
Not yet didn't find SP for Inventor LT 2014
TravisNave
Message 4 of 11 (3,261 Views)
12-17-2013 11:55 AM in reply to: roblawarre
Try getting the appropriate version here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322615&linkID=14002999
Good Luck!
Active Member
roblawarre
Message 5 of 11 (3,243 Views)
12-18-2013 05:05 AM in reply to: TravisNave
The link worked  ...  had to be patient downloaing because windows explorer was unstable.
New Member
Cacoethes333
Message 6 of 11 (3,089 Views)
12-28-2013 03:51 AM in reply to: roblawarre
I had the same issue with Inventor Lt Suite 2014 but with Windows 8.1. I finally fixed it and it now opens fine. My OS is a 64 bit system and my DVD was a 32 bit program, I un-installed all my Autocad programs then when to support and installed the Inventor Lt Suite 2014 but using the 64 bit system. It installed with no problem but sill didn't open the Inventor Lt. I then downloaded the SP1 for the 64 bit program, rebooted and now it works. I hope this helps. Lyle
Active Member
jacksondogsowner1
Message 7 of 11 (2,379 Views)
02-15-2014 03:56 PM in reply to: roblawarre
I followed the link and tried to install SP1 for Inventor LT 2014 after having gotten the 0xc0000142 error on windows 8 and it is telling me that the SP1 patch is not a valid patch.
I am running a Lenovo IdeaPad with Windows 8 64 bit.
I have already installed LT2014 and transferred the license using the license transfer utility successfully.
Any idea why I'd be having this problem?
Thanks!
New Member
npim
Message 8 of 11 (1,511 Views)
03-22-2014 12:46 PM in reply to: jacksondogsowner1
I am having the same problem with Inventor Professional on an IdeaPad Z580 64 bit running 8.1
New Member
295444
Message 9 of 11 (1,507 Views)
03-22-2014 12:59 PM in reply to: TravisNave
what version of auto cad support early 2008 macbook
New Member
npim
Message 10 of 11 (1,500 Views)
03-22-2014 04:24 PM in reply to: npim
edit:
when I have tried to run the updater for 32 and 64 bit I got an error along the lines of
the upgrade patch cannot be installed because some files are missing. verify that the program to be upgraded exists and that you have the correct upgrade patch.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
