Installation & Licensing
Inventor 2013 wont install
4 REPLIES 4
362 Views, 4 Replies
Ive been trying to download the student version of Inventor 2013 and a communication error shows up.  I've turned off the firewall which was recommended in the message and it still wont download. Any recommendations would be appreciated.
Jim
4 REPLIES 4
jessica.t
Hi Jim and welcome to the Autodesk Community!
Can you try the suggested tips in this solution regarding your same error? Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. If not, please reply to this post with further details. Thank you!
Jessica Thrasher
in reply to: jessica.t
Communication error still appears after applying the new rule.  Instructions are pretty vague on how to set it up through the wizard so I'm not sure if I did it write.  Is there a better source on how to go about opening the port to inventor?
*right
jessica.t
That came directly from the Microsoft site so it's likely the best source. But did you try the other steps? Changing your download method, changing browsers, disarming firewalls/antivirus, clearing your cookies and cache, disabling your UAC, etc.?
Jessica Thrasher
Administrator Productivity
