Not sure if this is known or it's just problem on my end:
I downloaded the Inventor 2013 setup from the Students' Website and when I ran the setup it found the product to be up to date and no service pack were need, which clearly seem not to be the case. I even ran Inventor afterward to check for update and it didn't find anything. Is there something wrong with the installer? (like it's a older built) or maybe you guys forgot to update that server which this particular installer built check? I only found out about the service pack by manually searching through the support website for extra stuff.
Thanks.
WinXP SP3
If you recently downloaded the product, it most likely already has the service pack installed as part of the package. Autodesk does this later during the release cycle.
Actually that doesn't seems to be the case but the problem is solved. I made the setup package into a iso disk image and run from a virtual drive and it detected the service pack.
