Installation & Licensing
Inventor 2013 Crashes as soon as I start to draw a sketch
3 REPLIES 3
PHILIPGreenleaves7329
486 Views, 3 Replies
I am operating Windows Vista on a Toshiba Laptop It is an Intel(R) Core(TM)2 Duo. 2.00GHz 4GB Ram.
The graphic display adapter is ATI Mobility RADEON HD 3470. I had been running Inventor 2012 without any trouble.
Is this an installation problem, or somethihg else? Looking at previous posts I can see others have had the same sort of problem with earlier versions.
3 REPLIES 3
It's almost certainly your video card.  ATI = Always Trashes Inventor. Smiley Very Happy I suspect the laptop does not meet recommended requirements.  You can check to see if there is a newer video driver.  I wish you luck.
Autodesk Forums:
o_krasikova
in reply to: TravisNave
I have the same problem on my HP Workstation. Win7,64. The graphic display adapter is NVIDIA NVS300.
TravisNave
in reply to: o_krasikova
Administrator Productivity
