Installation & Licensing
Inventor 2012 pro on Windows 8 FAIL WSE
2 REPLIES 2
albertuschw
1969 Views, 2 Replies
i try install inventor pro 2012 on windows 8
2012/12/21:20:39:26    ACW    UZDEROS    Installing Microsoft Visual C++ 2010 Redistributable (x86): G:\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\ACW\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/21:20:39:33    ACW    UZDEROS    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Succeeded
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {8D20B4D7-3422-4099-9332-39F27E617A6F}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {55D9E026-DCB0-46FF-B60A-68B972228CF6}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {450063AA-643B-417C-8CF5-405BA3F4EF40}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {106EC844-9F5E-4B72-BB3B-1E47D274A944}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {FACF203E-0F4D-489A-B80C-D185253C8FCB}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {1A2948E0-9445-42BE-9D01-472952F2657F}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {9A346205-EA92-4406-B1AB-50379DA3F057}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {C46C3C20-039E-4D7C-869F-9C0C05D65C06}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {577D60CB-0D5E-48D1-8850-84098AD34804}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {0576A3D0-0000-0409-0000-491C453655D7}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21}    Failed
2012/12/21:20:39:33    ACW    UZDEROS    Uninstall    {4780F600-0000-0409-0000-114715ACF216}    Failed
2012/12/21:20:39:34    ACW    UZDEROS    Installing Autodesk® Design Review 2012:   INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\"  ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:40:00    ACW    UZDEROS    Install    Autodesk® Design Review 2012    Succeeded
2012/12/21:20:40:00    ACW    UZDEROS    Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:40:19    ACW    UZDEROS    Install    Autodesk Material Library 2012    Succeeded
2012/12/21:20:40:21    ACW    UZDEROS    Installing Autodesk Material Library 2012 - Base Image Library:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:40:44    ACW    UZDEROS    Install    Autodesk Material Library 2012 - Base Image Library    Succeeded
2012/12/21:20:40:44    ACW    UZDEROS    Installing DirectX® Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/21:20:40:54    ACW    UZDEROS    Install    DirectX® Runtime    Succeeded
2012/12/21:20:40:55    ACW    UZDEROS    Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\ACW\AppData\Local\Temp\_AIA920.tmp\Media.mst"
 2012/12/21:20:43:03    ACW    UZDEROS    Install    Web Services Enhancements (WSE) 3.0 for Microsoft .NET    Failed    Installation aborted, Result=1603
2012/12/21:20:43:04    ACW    UZDEROS    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2012/12/21:20:43:34    ACW    UZDEROS    Rollback    Autodesk Material Library 2012 - Base Image Library    Succeeded
2012/12/21:20:43:58    ACW    UZDEROS    Rollback    Autodesk Material Library 2012    Succeeded
2012/12/21:20:44:10    ACW    UZDEROS    Rollback    Autodesk® Design Review 2012    Succeeded
2 REPLIES 2
DarrenP
in reply to: albertuschw
not a supported platform: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
also try searching these forums for workarounds and issues on Windows 8: http://forums.autodesk.com/t5/forums/searchpage/tab/message?q=windows+8
DarrenP
i did an upgrage from win 7 pro 64 with inventor pro 12 to win 8 and mirated my ''apps" and it works.
Administrator Productivity
