Installation & Licensing
Active Member
robert_hudson
Message 1 of 15 (2,939 Views)
Inventor 2012 Installation Error 1935
2939 Views, 14 Replies
02-15-2012 08:06 PM
I've tried just about everything I could find on the internet for a solution to this and still no luck. (Including deleting temp, registry fix, updates, .NET Framework checking, and others).
Employee
alison.gangler
Message 2 of 15 (2,888 Views)
Re: Inventor 2012 Installation Error 1935
02-17-2012 10:16 AM in reply to: robert_hudson
Please refer to the following post from the Windows Seven Forums regarding a similar issue when installing the Microsoft Visual C++ Redistributable package:
http://www.sevenforums.com/performance-maintenance/40511-set-registry-size-limit-unlimited-2.html
The posting indicates that the following steps will resolve the issue:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
Key: RegistrySizeLimit
Type: REG_DWORD
Value: 0xffffff (4294967295)
Reboot
As a Administrator open a Command Prompt and run "SFC /SCANNOW". The command should complete successfully and if any errors were found, they should be corrected.
It is always strongly recommended to fully back up the registry prior to making any modifications.
I hope this helps.
Cheers,
Alison
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
Active Member
robert_hudson
Message 3 of 15 (2,833 Views)
02-27-2012 09:00 AM in reply to: alison.gangler
Any chance you could give me some steps to perform this?
I did what I thought would be correct.
- Backed up the registry
- went to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
-created key RegistrySizeLimit
-set type to REG_DWORD
-set vaulue to 0xffffff (4294967295)
-performed clean boot
-attempted reinstall
xx Failed with the same error message at the same point
Active Member
robert_hudson
Message 4 of 15 (2,827 Views)
02-27-2012 09:56 AM in reply to: robert_hudson
Also, I checked for errors as you mentioned (forgot to include that in the last post)
Active Member
robert_hudson
Message 5 of 15 (2,815 Views)
02-27-2012 06:40 PM in reply to: robert_hudson
here is a screenshot of my attempt at a registry edit
TravisNave
Message 6 of 15 (2,803 Views)
02-28-2012 09:50 AM in reply to: robert_hudson
Just uninstall your Visual C++ and run the installer again.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
robert_hudson
Message 7 of 15 (2,795 Views)
02-28-2012 02:08 PM in reply to: TravisNave
Travis, I removed Visual C++ as you stated then attempted a reinstall. No luck. So i removed more (because well... why not) after restarting and having attempted another isntall.
The only thing that changed was now Autodesk Design Review installed, but still no inventor.
TravisNave
Message 8 of 15 (2,791 Views)
02-28-2012 02:39 PM in reply to: robert_hudson
You have admin rights?  UAC off?  Antivirus disabled?  Media or download install?
Active Member
robert_hudson
Message 9 of 15 (2,788 Views)
02-28-2012 03:35 PM in reply to: TravisNave
Admin Rights - check (even used install as admin during setup just to rule it out)
UAC - off
Microsoft Security Essentials - off
No other anti virus has ever been installed or used, I just freeze my C:
It's the download install - here is some log file. Thanks for your help as well
2012/2/28:16:59:06 Robert Hudson ROBERTHUDSON Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/2/28:16:59:06 Robert Hudson ROBERTHUDSON PageOpen ProductSelectionDialog2
2012/2/28:16:59:27 Robert Hudson ROBERTHUDSON PageOpen FullProgressDialog
2012/2/28:16:59:27 Robert Hudson ROBERTHUDSON Installing DirectX® Runtime: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/2/28:16:59:51 Robert Hudson ROBERTHUDSON Install DirectX® Runtime Succeeded
2012/2/28:16:59:51 Robert Hudson ROBERTHUDSON Installing Microsoft Windows Media Format 9.5 Series Runtime: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x64\wmf\95\wmfdist64.exe /quiet
2012/2/28:16:59:54 Robert Hudson ROBERTHUDSON Install Microsoft Windows Media Format 9.5 Series Runtime Failed Failure is ignored, Result=1603
2012/2/28:16:59:54 Robert Hudson ROBERTHUDSON Installing Autodesk® Inventor® 2012: TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\x64\en-us\Inventor\inventor.mst;C:\Users\ROBERT~1\AppData\Local\Temp\_AI6C59.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/28:17:05:33 Robert Hudson ROBERTHUDSON Install Autodesk® Inventor® 2012 Failed Installation aborted, Result=1603
2012/2/28:17:05:33 Robert Hudson ROBERTHUDSON Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Active Member
robert_hudson
Message 10 of 15 (2,783 Views)
02-28-2012 04:50 PM in reply to: robert_hudson
So looking at the logs, I actually paid attention and noticed that the error occured when installing file at path
which is microsoft windows media something or other 9.5? So i found that path, attempted a manual install, but i get error message "not enough storage is available to process this command" I assume this is where the real issue lies but again, I have no idea what to do /:
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
