• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    robert_hudson
    Accepted Solution
    Inventor 2012 Installation Error 1935
    1586 Views, 14 Replies
    02-15-2012 08:06 PM
    I've tried just about everything I could find on the internet for a solution to this and still no luck. (Including deleting temp, registry fix, updates, .NET Framework checking, and others).
    Please use plain text.
    Product Support
    Re: Inventor 2012 Installation Error 1935
    02-17-2012 10:16 AM in reply to: robert_hudson
    Please refer to the following post from the Windows Seven Forums regarding a similar issue when installing the Microsoft Visual C++ Redistributable package:
    http://www.sevenforums.com/performance-maintenance/40511-set-registry-size-limit-unlimited-2.html
    The posting indicates that the following steps will resolve the issue:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
    Key: RegistrySizeLimit
    Type: REG_DWORD
    Value: 0xffffff (4294967295)
    Reboot
    As a Administrator open a Command Prompt and run "SFC /SCANNOW". The command should complete successfully and if any errors were found, they should be corrected.
    It is always strongly recommended to fully back up the registry prior to making any modifications.
    I hope this helps.
    Cheers,
    Alison
    ___________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Alison Gangler
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    robert_hudson
    02-27-2012 09:00 AM in reply to: alison.gangler
    Any chance you could give me some steps to perform this?
    I did what I thought would be correct.
    - Backed up the registry
    - went to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
    -created key RegistrySizeLimit
    -set type to REG_DWORD
    -set vaulue to 0xffffff (4294967295)
    -performed clean boot
    -attempted reinstall
    xx Failed with the same error message at the same point
    Active Member
    robert_hudson
    02-27-2012 09:56 AM in reply to: robert_hudson
    Also, I checked for errors as you mentioned (forgot to include that in the last post)
    Active Member
    robert_hudson
    02-27-2012 06:40 PM in reply to: robert_hudson
    here is a screenshot of my attempt at a registry edit
    *Expert Elite*
    TravisNave
    02-28-2012 09:50 AM in reply to: robert_hudson
    Just uninstall your Visual C++ and run the installer again.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    robert_hudson
    02-28-2012 02:08 PM in reply to: TravisNave
    Travis, I removed Visual C++ as you stated then attempted a reinstall. No luck. So i removed more (because well... why not) after restarting and having attempted another isntall.
    The only thing that changed was now Autodesk Design Review installed, but still no inventor.
    *Expert Elite*
    TravisNave
    02-28-2012 02:39 PM in reply to: robert_hudson
    You have admin rights?  UAC off?  Antivirus disabled?  Media or download install?
    Travis Nave
    Active Member
    robert_hudson
    02-28-2012 03:35 PM in reply to: TravisNave
    Admin Rights - check (even used install as admin during setup just to rule it out)
    UAC - off
    Microsoft Security Essentials - off
    No other anti virus has ever been installed or used, I just freeze my C:
    It's the download install - here is some log file. Thanks for your help as well
    2012/2/28:16:59:06 Robert Hudson ROBERTHUDSON Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
    2012/2/28:16:59:06 Robert Hudson ROBERTHUDSON PageOpen ProductSelectionDialog2
    2012/2/28:16:59:27 Robert Hudson ROBERTHUDSON PageOpen FullProgressDialog
    2012/2/28:16:59:27 Robert Hudson ROBERTHUDSON Installing DirectX® Runtime: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
    2012/2/28:16:59:51 Robert Hudson ROBERTHUDSON Install DirectX® Runtime Succeeded
    2012/2/28:16:59:51 Robert Hudson ROBERTHUDSON Installing Microsoft Windows Media Format 9.5 Series Runtime: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\3rdParty\x64\wmf\95\wmfdist64.exe /quiet
    2012/2/28:16:59:54 Robert Hudson ROBERTHUDSON Install Microsoft Windows Media Format 9.5 Series Runtime Failed Failure is ignored, Result=1603
    2012/2/28:16:59:54 Robert Hudson ROBERTHUDSON Installing Autodesk® Inventor® 2012: TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\x64\en-us\Inventor\inventor.mst;C:\Users\ROBERT~1\AppData\Local\Temp\_AI6C59.tmp\x64\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/2/28:17:05:33 Robert Hudson ROBERTHUDSON Install Autodesk® Inventor® 2012 Failed Installation aborted, Result=1603
    2012/2/28:17:05:33 Robert Hudson ROBERTHUDSON Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
    Active Member
    robert_hudson
    02-28-2012 04:50 PM in reply to: robert_hudson
    So looking at the logs, I actually paid attention and noticed that the error occured when installing file at path
    which is microsoft windows media something or other 9.5? So i found that path, attempted a manual install, but i get error message "not enough storage is available to process this command" I assume this is where the real issue lies but again, I have no idea what to do /:
