Installation & Licensing
Member
Moff14
Message 1 of 4 (904 Views)
Inventor 2012 Install problems
904 Views, 3 Replies
07-06-2011 09:11 AM
Having problems gettting Inventor 2012 to install.
First attempt failed on Design Review, now failed twice on Sketchbook Designer.
Error message is:       1: 5 2: adlmPITSetProductInformation failed. 3: 2
Windows 7 64-bit
Intel Core i7
Log attached.
Product Support
emily.xu
Message 2 of 4 (890 Views)
Re: Inventor 2012 Install problems
07-06-2011 09:00 PM in reply to: Moff14
Maybe a corruption in the ProductInformation.pit file.  The workaround is to manually remove this file and then run the installation process again.
The ProductInformation.pit file can be found on the workstation in the following locations:
Windows XP:
C:\Documents and settings\All Users\Application Data\Autodesk\ADLM\ProductInformation.pit
Windows Vista:
C:\ProgramData\Autodesk\ADLM\ProductInformation.pit
Emily Xu
Member
Moff14
Message 3 of 4 (876 Views)
07-07-2011 04:40 AM in reply to: emily.xu
Ok, removed the file as requested and the installation has progressed a bit further, but not too far.
An error is not flashing up about needing to shut down Windows Explorer.
Any action after this kills the install.
Product Support
emily.xu
Message 4 of 4 (859 Views)
07-07-2011 06:17 PM in reply to: Moff14
I would suggest you remove all the Autodesk Products first, especially delete related folders and registers by this solution: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240697.
Then use your administrator user to login your machine, close all the others applications, including anti-virus and firewall,close UAC and try to reinstall from a clean system.
Hope helps.
Emily Xu
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
