Good day,
In my expirience I have created a lot of Autdesk products but have never encountered following problem. First I'll try to fill in with what i have been doing.
5. Published it to PC
6. Installation succeeds and logs ends with exit code 0
7. Problem starts here. I can open Showcase. But when i try to open Inventor 2012 it opens loading screen (process invetor.exe starts) and after a minute or so it (loading screen and process) closes. Windows event viewer doesn't get any errors, ProcessMonitor doesn't show any failed command attempts.
I have tried to install this manually without gpo.mst and the result is the same.
[!!!] If i launch setup.exe with .ini config file everything works just fine.
Only thing i can suspect now is that there are some special properties or hidden prerequisites installed with setup.exe that are not included in just .msi with .mst. Athough I looked at .ini and didn't see anything special there.
So could someone please share knowledge with Inventor installation from MSI? Thank you in advance.
Solved by hashim.mundol. Go to Solution.
I've found something in ProgramData folder logs. Here is the part of log.
1184 2012/01/12 11:03:26 Reason=Fatal error 1184 2012/01/12 11:03:26 ComputerName=MYPCNAME 1184 2012/01/12 11:03:26 OS=6.1.7600. 1184 2012/01/12 11:03:26 File=AdlmIntNWFBLicense.cpp,Line=766 1184 2012/01/12 11:03:26 VendorID=3 [FLEXLM-NW] 1184 2012/01/12 11:03:26 VendorError=-96 [Server node is down or not responding] 1184 2012/01/12 11:03:26 FLEXLM-NW=v11.9.0.0 build 87342 x64_n6 1184 2012/01/12 11:03:26 Reason=Fatal error 1184 2012/01/12 11:03:26 ComputerName=MYPCNAME 1184 2012/01/12 11:03:26 OS=6.1.7600. 1184 2012/01/12 11:03:26 File=AdlmIntNWFBLicense.cpp,Line=749 1184 2012/01/12 11:03:26 AdlmIntError=20 [License check out failed] 1184 2012/01/12 11:03:26 Reason=Fatal error 1184 2012/01/12 11:03:26 ComputerName=MYPCNAME 1184 2012/01/12 11:03:26 OS=6.1.7600. 1184 2012/01/12 11:03:26 File=AdlmIntLicense.cpp,Line=612 1184 2012/01/12 11:03:26 VendorID=6 [ADLMPIT] 1184 2012/01/12 11:03:26 VendorError=12 [The root information in Product Information Table XML file is missing] 1184 2012/01/12 11:03:26 Reason=Fatal error 1184 2012/01/12 11:03:26 ComputerName=MYPCNAME 1184 2012/01/12 11:03:26 OS=6.1.7600. 1184 2012/01/12 11:03:26 File=AdlmIntLicense.cpp,Line=613 1184 2012/01/12 11:03:26 AdlmIntError=25 [The product key was not found]
And this is really strange. I have checked properties for .mst ACADSERIALNUMBER, ACADSERIALPREFIX and ADLM_PRODKEY is filled with correct info. I am using also ACADSERVERPATH which is not accesible at the machine where i test this but shouldn't it just popup flexera window to provide new server path or license key file the same like it is for Showcase?
AdminImage\x64\en-us\Inventor\InventorLP.msi should also include the same .mst as Inventor.msi. i.e. with AdminImage\x64\Inventor\inventor-mydeployment.mst and Tools\gpo.mst
