• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    Inventor 2012 Content Centre
    540 Views, 1 Replies
    07-12-2011 01:45 AM
    I have downloaded the installations files for Inventor 2012 from the Autodesk Website.
    I normally create a deployment image to install AutoCAD and Inventor onto several machines.
    For Inventor 2010 we had to deploy the image and then install the content centre separately using the disks as we have them stored locally on each machine.
    I have been reading the help files, for Inventor 2012 installations, and it says "To add a default library after installation, run setup.exe from the Installation media and select the check box next to the libraries you want to install".
    My question is can I install the content centre from the setup files I have downloaded from the website, or must I have the installation files on Media.
    Thanks.
    Please use plain text.
    TravisNave
    Re: Inventor 2012 Content Centre
    07-12-2011 07:17 AM in reply to: moosabismillah
    If you have downloaded the content center libraries, you can use that to install in lieu of the physical media.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
