please go to "Application Options"-"Hardward" tabs and change the different options for Graphic setting, also, you can click "Diagnostics" to check if your graphic driver has been certified.
You can also try to turn off your hardware acceleration to see if the problem can be solved.
Emily Xu, Autodesk Product Support
We appreciate your quick feedback on this forum
Emily Xu
Product Support
