Installation & Licensing
Inventor 2011 SAP SP2 to Vault 2012 update??
4 REPLIES 4
guyh
300 Views, 4 Replies
I am trying to find the update (hotfix) for Inventor 2011 (with subscription advantage pack) which will allow the Vault addin to work with Vault client 2012.  I have tried using the new download section which is terrible it has to be said in order to find the download.  I have found old links which are now broken.  I need this ASAP so if anybody can help it would be very much appreciated.
Guy
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
4 REPLIES 4
TravisNave
in reply to: guyh
I just spent 15 minutes looking for this for you.  It is miserable how bad the new downloads section is, along with all the previously working links now being invalid.  I feel your pain.
Hopefully someone at Autodesk will see this and provide you the correct link.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
guyh
in reply to: TravisNave
Thanks Travis, I am glad it is not just me then. It seems it's all style and no substance.
I believe I have been able to find the files, downloading now.
http://knowledge.autodesk.com/search-result/caas/downloads/content/updated-6302011-autodesk-inventor...
I hope this helps others. I have to find out what the actual file msp was called and google it to get to that page. I could not find it through the Autodesk support area.
Cheers,
Guy
AutoCADM 2011 SP2
TravisNave
in reply to: guyh
Well done.  Why this wasn't clearly listed on either Inventor or Vault's download support page is beyond me.  It should not have been that hard.
Autodesk Forums:
guyh
Subscription advantage pack download. The one above is for SP2.
AutoCADM 2011 SP2
Administrator Productivity
