Emily Xu, Autodesk Product Support
We appreciate your quick feedback on this forum
1. We only saw Inventor Suite 2011 available for download... We did not see Inventor Pro 2011 available for download... We will look again...
2. Autodesk is no longer sending us original disks for Inventor 2011... We are told we have to download everything now...
3. We see the following information on your site when looking to download Inventor Pro 2011:
The AutoCAD Inventor 2011 Suite download supports the following five products:
AutoCAD Inventor Suite
AutoCAD Inventor Routed Systems Suite
AutoCAD Inventor Simulation Suite
AutoCAD Inventor Tooling Suite
AutoCAD Inventor Professional Suite
You will be asked to enter your serial number and product key during the installation process.
Installation of the correct product is managed automatically by the installation program.
Does this mean that both Inventor and Inventor Pro are included in the downloaded installation files??
4. I currently have a HULA companion S/N being used for Inventor Pro 2008 on one of my home computers... I want to replace my Inventor Pro 2008 installation with an Inventor Pro 2011 installation on a new home computer... Can I use the same HULA companion S/N for my new 2011 installation on a new home computer?
Edited by: gemston1@optonline.net on Apr 22, 2010 10:38 AM
Thanks for your response...
But you did not exactly answer my question regarding the license... At my job we have a network license... Approximately 3 months ago I submitted and obtained a serial number and authorization code for home use of Inventor Pro 2008...Now I have a new computer at home and I now want to do a new install of Inventor Pro 2011 on the new computer... Can I use my current serial number and authorization code to activate Inventor Pro 2011 on my new home computer??...
Also, you say Autodesk Inventor Suite 2011 is different from Autocad Inventor Suite 2011... What is the difference??
Edited by: gemston1@optonline.net on Apr 23, 2010 7:22 AM
Yes,you can use the S/N to install Inventor Pro 2011. But the authorization code is generated by your S/N and requirement code. so I think you should install fisrt, then run your application, get the requirement code to apply the authorization code to active your application.
Also, I say "Autodesk Inventor 2011Suite is different from Autocad Inventor Suite 2011", Autodesk Inventor 2011Suite is a package which include Autocad Inventor Suite 2011, and other components such as Autocad Inventor Routed Suite 2011, Autocad Inventor Simulation Suite 2011 and Autocad Inventor tooling Suite2011.
