Yes, I know, Inventor 2008 is old. It's not designed to run on Win7. I should upgrade...
Fact is, I like 2008 and don't care for the Ribbon interface on the newer versions.
I have a new computer which I'm trying to bring up. I installed Inventor 2008 and have installed SP3.
Problem is when I bring up a part or assembly file Inventor crashes. I currently have it set for XP Compatibility mode.
System is a Core i7 processor. GeForce TGX 550Ti graphics card.
I"m open to any and all suggestions as to how to get this thing working.
Here is the info from Hardware Diagnostics:
This Direct3D graphics driver is not Microsoft WHQL certified
Graphics Hardware Description: NVIDIA GeForce GTX 550 Ti
Direct3D \ Hardware Renderer
Graphics driver file nvd3dum.dll is version 8.17.12.7533
Using Full optimization (this is the recommended setting)
The display is using 32-bit color
Inventor Version:
Build: 320, Release: 2008 SP2 - Date: Mon 11/26/2007
Loaded Inventor Add-Ins:
Content Center
Autodesk DWF Markup Manager
Content Center Connectivity
Content Center Item Translator
Frame Generator
Drag & Drop Interoperability
Design Accelerator
AEC Exchange
AutoLimits
Inventor Studio
EDM Addin
System Information:
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 05/02/12 14:57:28 Ver: 10.15
Processor: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz (8 CPUs), ~3.4GHz
System Memory: 16384MB RAM
Page File: 2599MB used, 30072MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7601.17514
Graphics Device Information:
DirectX Version: 9.0c
Renderer: HAL
Adapter Description: NVIDIA GeForce GTX 550 Ti
DDI Version: 11
DDI Version Number: b
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Manufacturer: NVIDIA
Chip Type: GeForce GTX 550 Ti
DAC Type: Integrated RAMDAC
Revision:
Vendor ID string: 0x000010de
Device ID string: 0x00001244
Graphics HW Memory: 4065 MB
Display Mode: 1280 x 1024 (32 bit) (60Hz)
VendorID: 10de
DeviceID: 1244
SubSystemID: 15563842
Revision: a1
Graphics driver file: nvd3dum.dll
Driver file version: 8.17.12.7533
WHQL Level: 0
Inventor Graphics Device Information:
Hardware Library ID: Direct3D \ 0x000010de \ 0x00001244
Direct3D Hardware ID: 10de \ 1244 \ 15563842 \ a1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Inventor Hardware Library Information:
HW Library Version = $Revision: #1 $
HW Library Date = $DateTime: 2007/07/24 09:03:00 $
HW Library OS Name = Windows XP
Inventor Hardware Library Entry Information:
Autodesk Inventor Certification Status: Unknown
Autodesk Inventor Tested Certification Status: Unknown
Graphics HW Vendor Supported for Autodesk Inventor: False
Hardware Library 2.0\0x000010de
Settings for optimized and conservative:
Workarounds: 0x00000000, 0x00000000
rating 0, optimization level 2
Texture Font Precision: 32
Display Information:
Back Buffer Format = A8R8G8B8
Depth Stencil Buffer Format = D24S8
Monochrome Bitmap Format = A8
Device Adapter Information:
AdapterOrdinal = 0
MasterAdapterOrdinal = 0
AdapterOrdinalInGroup = 0
NumberOfAdaptersInGroup = 1
Device Processing Information:
DeviceType = 1
Device Behavior = 0x00000042
Vertex Processing = Hardware
Device Transform and Light = Hardware
Device Rasterization = Hardware
Supports SlopeScaleDepthBias = True
Supports DepthBias = True
Supports CubeMaps = True
Supports Non-Power-Of-2 Textures = True
Supports Non-Power-Of-2 Textures Conditionally = False
Device Size Limits:
MaxPrimitiveCount = 16777215
MaxVertexIndex = 16777215
MaxTextureWidth = 8192
MaxTextureHeight = 8192
MaxSimultaneousTextures = 8
NumSimultaneousRTs = 4
MaxActiveLights = 8
MaxUserClipPlanes = 8
Device Shader Information:
VertexShaderVersion = 3.0
PixelShaderVersion = 3.0
MaxVertexShaderConst = 256
PixelShader1xMaxValue = 6.550400E+004
MaxVShaderInstructionsExecuted = 65535
MaxPShaderInstructionsExecuted = 65535
MaxVertexShader30InstructionSlots = 4096
MaxPixelShader30InstructionSlots = 4096
VS20Caps = 0x00000001
DynamicFlowControlDepth = 24
NumTemps = 32
StaticFlowControlDepth = 4
PS20Caps = 0x0000001f
NumTemps = 32
NumInstructionSlots = 512
The Remainder of the Device Caps Information:
Caps = 0x00020000
Caps2 = 0xe0020000
Caps3 = 0x000003a0
PresentationIntervals = 0x8000000f
CursorCaps = 0x00000001
DevCaps = 0x001bbef0
PrimitiveMiscCaps = 0x002fcef2
RasterCaps = 0x07732191
ZCmpCaps = 0x000000ff
SrcBlendCaps = 0x00003fff
DestBlendCaps = 0x00003fff
AlphaCmpCaps = 0x000000ff
ShadeCaps = 0x00084208
TextureCaps = 0x0001ecc5
TextureFilterCaps = 0x03030700
CubeTextureFilterCaps = 0x03030300
VolumeTextureFilterCaps = 0x03030300
TextureAddressCaps = 0x0000003f
VolumeTextureAddressCaps = 0x0000003f
LineCaps = 0x0000001f
MaxVolumeExtent = 2048
MaxTextureRepeat = 8192
MaxTextureAspectRatio = 8192
MaxAnisotropy = 16
StencilCaps = 0x000001ff
FVFCaps = 0x00180008
TextureOpCaps = 0x03feffff
StretchRectFilterCaps = 0x03000300
VertexTextureFilterCaps = 0x03030700
MaxTextureBlendStages = 8
DeclTypes = 0x0000030f
VertexProcessingCaps = 0x0000013b
MaxVertexBlendMatrices = 4
MaxVertexBlendMatrixIndex = 0
MaxPointSize = 8.192000E+003
MaxStreams = 16
MaxStreamStride = 255
DevCaps2 = 0x00000051
MaxNpatchTessellationLevel = 0.000000E+000
MaxVertexW = 1.000000E+010
GuardBandLeft = -1.000000E+008
GuardBandTop = -1.000000E+008
GuardBandRight = 1.000000E+008
GuardBandBottom = 1.000000E+008
ExtentsAdjust = 0.000000E+000
Reserved5 = 0x00000000
Your best bet is to update the video card driver to something WHQL certified (even if your old product libraries do not say it is.)
Update to this driver and make sure that your Inventor is running as Administrator in XP or Vista mode. You will also want to disable UAC and possibly make an exception in your anti-virus for the Inventor folder.
http://www.nvidia.com/object/win7-winvista-64bit-301.42-whql-driver.html
