Dear Mr / Mrs
I have a really big problem in installing autocad on my computer i have been trying 2011 verion then 2012 then 2013 and no one works on my labtop first the problem was 32 bit and 64 bit as mine is 64 so i fixed it then the problem is now with version 2013 that the installtion complete . some products failed to install , i followed your instructions on the website i closed the antivirus and closed the network tried to install it but same message appear then i loaded (Microsoft Visual C++ 2010) and from the control panel removed others ....... ETC
this is the log error
2013/11/27:19:22:49 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/11/27:19:22:49 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/11/27:19:23:20 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/11/27:19:22:54 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/11/27:19:22:54 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/11/27:19:23:20 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/11/27:19:23:52 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/11/27:19:23:52 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/11/27:19:23:56 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/11/27:19:23:56 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/11/27:19:23:57 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/11/27:19:24:06 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/11/27:19:25:08 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/11/27:19:25:10 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/11/27:19:25:10 Maiousha Zizo MAIOUSHAZIZO-PC Installing .NET Framework Runtime 4.0 KB2468871: C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/11/27:19:31:29 Maiousha Zizo MAIOUSHAZIZO-PC Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/11/27:19:31:29 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\MAIOUS~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/11/27:19:31:29 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/11/27:19:31:30 Maiousha Zizo MAIOUSHAZIZO-PC Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2013/11/27:19:31:32 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/11/27:19:32:00 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/11/27:19:40:06 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/11/27:19:40:06 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/11/27:19:40:25 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/11/27:19:40:11 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/11/27:19:40:11 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/11/27:19:40:25 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/11/27:19:40:42 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/11/27:19:40:42 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/11/27:19:40:55 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/11/27:19:40:56 Maiousha Zizo MAIOUSHAZIZO-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/27:19:40:57 Maiousha Zizo MAIOUSHAZIZO-PC Install Network License Manager Succeeded
2013/11/27:19:40:57 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\MAIOUS~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/11/27:19:40:57 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/11/27:19:40:59 Maiousha Zizo MAIOUSHAZIZO-PC Rollback Network License Manager Succeeded
2013/11/27:19:40:59 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/11/27:19:42:57 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/4:10:26:32 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/4:10:26:32 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/4:10:27:00 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/4:10:26:34 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/4:10:26:34 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/4:10:26:58 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/4:10:27:40 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/4:10:27:50 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/4:10:28:21 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/4:10:28:24 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/4:10:28:24 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\MAIOUS~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/12/4:10:28:24 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/4:10:28:26 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/4:10:28:47 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/4:10:29:58 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/4:10:29:58 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/4:10:30:01 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/4:10:30:01 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/4:10:30:50 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen BeginDeploymentDialog
2013/12/4:10:30:57 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/4:10:31:25 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/4:10:31:25 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/4:10:32:37 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/4:10:32:37 Maiousha Zizo MAIOUSHAZIZO-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\autocad\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/4:10:32:40 Maiousha Zizo MAIOUSHAZIZO-PC Install Network License Manager Succeeded
2013/12/4:10:32:40 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\MAIOUS~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/12/4:10:32:40 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/4:10:32:44 Maiousha Zizo MAIOUSHAZIZO-PC Rollback Network License Manager Succeeded
2013/12/4:10:34:37 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/4:10:34:37 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/4:10:34:37 Maiousha Zizo MAIOUSHAZIZO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/12/4:10:34:40 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/4:10:34:46 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/4:10:34:46 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/4:10:34:46 Maiousha Zizo MAIOUSHAZIZO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/12/4:10:34:47 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/4:10:42:01 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/4:10:42:01 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/4:10:42:45 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/4:10:42:06 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/4:10:42:06 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/4:10:42:06 Maiousha Zizo MAIOUSHAZIZO-PC [Error: 1052] The requested control is not valid for this service.
2013/12/4:10:42:39 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/4:10:42:54 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/4:10:42:59 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/4:10:43:41 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/4:10:44:10 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/4:10:44:10 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\MAIOUS~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/12/4:10:44:10 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/4:10:44:15 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/4:11:40:57 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:26:44 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:26:44 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:14:27:08 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:26:48 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:26:48 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:14:27:04 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/10:14:27:21 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/10:14:27:25 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/10:14:27:56 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/10:14:27:59 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/10:14:27:59 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\MAIOUS~1\AppData\Local\Temp\vcredist_x64_2010.log
2013/12/10:14:27:59 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/10:14:28:03 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/10:14:36:11 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:38:35 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:38:35 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:14:38:40 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:38:36 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:38:36 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:14:38:40 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/10:14:38:42 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/10:14:38:46 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/10:14:38:56 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/10:14:38:58 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/10:14:38:58 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\MAIOUS~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/12/10:14:38:58 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=2
2013/12/10:14:38:59 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/10:14:43:17 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:47:00 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:47:00 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:14:47:09 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:47:03 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:47:03 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:14:47:08 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/10:14:47:12 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/10:14:47:18 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/10:14:47:39 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/10:14:50:02 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/10:14:50:02 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/12/10:14:50:02 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/10:14:50:07 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/10:14:50:31 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:59:46 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:59:46 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:00:01 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:14:59:49 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:14:59:49 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:00:01 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/10:15:00:03 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/10:15:00:08 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/10:15:00:23 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/10:15:00:36 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/10:15:00:36 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/12/10:15:00:36 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/10:15:08:41 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:15:08:41 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:08:41 Maiousha Zizo MAIOUSHAZIZO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/12/10:15:08:46 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:15:00:39 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/10:15:08:53 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:15:08:55 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:15:08:55 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:09:00 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:15:08:56 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:15:08:56 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:09:00 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/10:15:09:04 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/10:15:09:07 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/10:15:09:14 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/10:15:09:17 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/10:15:09:17 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/12/10:15:09:17 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/10:15:09:18 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/10:15:09:27 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:15:09:31 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:15:09:31 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:09:36 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:15:09:32 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:15:09:32 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:09:36 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/10:15:09:38 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/10:15:09:41 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/10:15:09:48 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/10:15:10:28 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/10:15:10:28 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/12/10:15:10:28 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=2
2013/12/10:15:10:29 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen InstallCompleteDialog
2013/12/10:15:17:10 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:15:18:13 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:15:18:13 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:18:27 Maiousha Zizo MAIOUSHAZIZO-PC === Setup ended ===
2013/12/10:15:18:16 Maiousha Zizo MAIOUSHAZIZO-PC === Setup started on MAIOUSHAZIZO-PC by Maiousha Zizo ===
2013/12/10:15:18:16 Maiousha Zizo MAIOUSHAZIZO-PC Launch
2013/12/10:15:18:21 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LaunchDialog
2013/12/10:15:18:46 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen LicenseDialog
2013/12/10:15:18:50 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductInfoDialog
2013/12/10:15:18:55 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen ProductSelectionDialog2
2013/12/10:15:18:57 Maiousha Zizo MAIOUSHAZIZO-PC PageOpen FullProgressDialog
2013/12/10:15:18:57 Maiousha Zizo MAIOUSHAZIZO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Maiousha Zizo\Desktop\New folder (2)\C\Recovered NTFS Partition @ 546396160\mona\AutoCad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/12/10:15:18:57 Maiousha Zizo MAIOUSHAZIZO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=2
Thanks waiting your kind reply ..
The problem is definitely C++. Have you tried installing it manually?
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Thanks for your reply but please send me the link again because it's not working ,
Thanks. I need to file that as a bug report.
The URL is:
or you can click the edit setup.ini link in my signature.
Thanks.
