I tried to install AutoCAD 2015 but I have a 0.0.0 error I searched And I found that I need Lmtools 11.12 so I used this lmtools http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Latest-... and didnt work so I found again about the time in the server , but its fine so I found something about delete cadeInfo.cas and I did it but it didnt work so what can I do to fix this problem thanks?.
Post the debug log from your LMTOOLS and that will help verify if adskflex.exe is still running an older cached version.
