Installation & Licensing
Instillation Fail for Revit 2012 (ED)
3 REPLIES 3
bcano1325
342 Views, 3 Replies
I cannot seem to get past the page that says:
Autodesk Revit Architecture 2012
Autodesk Design Review 2012
Autodesk Material Library 2012- Medium Image Library
The window states that the Instilaltion is complete but some products failed to install (all 3)
I am running W7 and I downloaded Revit 2012
Appreciate the help
3 REPLIES 3
DarrenP
in reply to: bcano1325
your not really giving us any info
based off the info you have given it could hundreds of things
did you look at the install log?
DarrenP
bcano1325
Sorry I didn't mean to be so vague. This is the last thing that showed up in the log.
2013/2/16:03:34:12    Robo-Panda Z    ROBO-PANDAZ-PC    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\ROBO-P~1\AppData\Local\Temp\vcredist_x86_2010.log
2013/2/16:03:34:16    Robo-Panda Z    ROBO-PANDAZ-PC    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
thanks for the help
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Administrator Productivity
