• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Instatllation Issues
    239 Views, 5 Replies
    11-29-2012 08:01 AM
    tobts: license server UP (MASTER) v11.7
    Vendor daemon status (on tobts):
      adskflex: The desired vendor daemon is down.  Check the lmgrd log file, or try lmreread. Vendor:Host:   tobts License path:  27000@tobts; FLEXnet Licensing error:-97,121\
    I've gone into LMtools and double checked the ethernet mac address.  It is correct.  I also changed the port setting in the license file from 2080 to 27010, but I still get the same error.
    Please use plain text.
    TravisNave
    Re: Instatllation Issues
    11-29-2012 03:28 PM in reply to: TownofBlacksburg
    The port settings for adskflex must be set to 2080 so set it back.  The master daemon will automatically use 27000-27009 depending on what is available.  Do not attempt to modify your LIC file at all or you risk invalidating it.
    What you might have is another connection problem.  What do you get when you PING the server?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    Re: Installation Issues
    11-30-2012 04:56 AM in reply to: TravisNave
    The NLM and the distribution server are the same server.  They are installed on a virtual terminal server I don't have any network communication issues.  The initial test distribution for the install was done under a login profile on this same server.  I changed the port back, stopped the service, restarted, and did a reread, but I still have the same error.
    TravisNave
    11-30-2012 08:17 AM in reply to: TownofBlacksburg
    In that case, you need to verify IPv6 with PING.  If it is Server 2008, that is likely the issue.  Just point to the 127.0.0.1 localhost with a modification to your hosts file.  Then add all four .exe files for the NLM to the firewall exception list.  This should resolve it.
    For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
    Travis Nave
    Member
    12-03-2012 10:00 AM in reply to: TravisNave
    This worked, but I have another isssue.
     When I attempt to deploy from the share file on my 2008 server the install pops up with the following error;
                             The copy functions cannot be used.
                                           \\ ServerName\Civil 3D\AdminImage\*.exe
                                           to
                                            C:\users\username\AppData\Local\Temp\_AI2BE1.tmp
    I'm running this on a Windows 7 machine I have full admin rights.  The FireWall is off and I have full admin rights and read\wright rights to the share on the server.
    TravisNave
    12-05-2012 07:34 AM in reply to: TownofBlacksburg
    Make sure any anti-virus or other network protection is off.  Try installing as the local administrator account, if you must.
    Travis Nave
