I'm an ICT engineer at a construction company in Belgium. One of my collegues who works with Autocad had an issue with her laptop.
I've reinstalled her pc, and before doing that i exported the license via portable license utility. Problem is I didn't RTFM (in proper: didn't read the manual), and didn't insert the activation identification code from the target machine on the source machine (basically the same machine, only reinstalled).
So i don't have the option to transfer the license to another computer and i don't have the option to import the license back to the original installation.
Can anyone help me with activating/setting the right license?
Thnx in advance.
Solved by hashim.mundol. Go to Solution.
If you are unable to activate online, you could try to get activation codes usiing one of the methods mentioned here.
http://usa.autodesk.com/adsk/servlet/item?linkID=9241177&id=5584421&siteID=123112
didn't think of online activations (stupid me)
Works like a charm, thnx 🙂
