Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Installing individual products from Suite product
- Highlight
- Email to a Friend
- Report Inappropriate Content
What do we need in order to install a single product from a Suite product?
For instance, say I would like only to copy over just the Navisworks Manage 64 bit portion of the Building Design Suite Ultimate installation. Could I simply copy the folder ...\AdminImage\x64\NAVMAN folder? Does it have all the necessary components for installation?
Re: Installing individual products from Suite product
- Highlight
- Email to a Friend
Unlikely. Just create a deployment with only that product selected and it will only install that product. That should be the easiest.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Installing individual products from Suite product
- Highlight
- Email to a Friend
Installed Navisworks Manage from a Building Design Suite product by going into the NAVMAN folder and using the roamer.msi.
But I was not able to launch Revit Structure in the same way with the RST2012.msi in its folder. It gave me a 1604 error.
So it's hit a miss. Creating single deployments should be the way to go. Thanks.
