What do we need in order to install a single product from a Suite product?
For instance, say I would like only to copy over just the Navisworks Manage 64 bit portion of the Building Design Suite Ultimate installation. Could I simply copy the folder ...\AdminImage\x64\NAVMAN folder? Does it have all the necessary components for installation?
Solved by TravisNave. Go to Solution.
Unlikely. Just create a deployment with only that product selected and it will only install that product. That should be the easiest.
Installed Navisworks Manage from a Building Design Suite product by going into the NAVMAN folder and using the roamer.msi.
But I was not able to launch Revit Structure in the same way with the RST2012.msi in its folder. It gave me a 1604 error.
So it's hit a miss. Creating single deployments should be the way to go. Thanks.
