I have a server deploy to installa CAD2013.
My cenario:
Windows 7 Enterprise x64
user: Local Administrator or domain user with local admin privileges
Error encountered:
After start deployment the pre-requisits install like a charm. When the Revit starts installation, occur some error and the rollback occur.
The end of logfile in %tem% (Autodesk Revit 2013 Install.log, 10Mb file) is above:
My user have full access in c:\windows\installer\ and sub-folders. Some help?? 😞
MSI (s) (50:DC) [16:51:23:212]: Note: 1: 1708
MSI (s) (50:DC) [16:51:23:212]: Product: Revit 2013 - - Installation operation failed.
MSI (s) (50:DC) [16:51:23:212]: O Windows Installer instalou o produto. Nome do Produto: Revit 2013. Versão do Produto: 12.02.21203. Idioma do Produto: 1033. Fabricante: Autodesk. Status de erro ou êxito da instalação: 1603.
MSI (s) (50:DC) [16:51:23:212]: Attempting to delete file C:\windows\Installer\1e1fd92.mst
MSI (s) (50:DC) [16:51:23:212]: Unable to delete the file. LastError = 32
MSI (s) (50:DC) [16:51:23:212]: Attempting to delete file C:\windows\Installer\1e1fd93.mst
MSI (s) (50:DC) [16:51:23:212]: Attempting to delete file C:\windows\Installer\1e1fd98.mst
MSI (s) (50:DC) [16:51:23:212]: Deferring clean up of packages/files, if any exist
MSI (s) (50:DC) [16:51:23:228]: Attempting to delete file C:\windows\Installer\1e1fd98.mst
MSI (s) (50:DC) [16:51:23:228]: Unable to delete the file outside of the engine. LastError = 2
MSI (s) (50:DC) [16:51:23:228]: MainEngineThread is returning 1603
MSI (s) (50:E8) [16:51:23:228]: RESTART MANAGER: Session closed.
MSI (s) (50:E8) [16:51:23:228]: No System Restore sequence number for this installation.
=== Logging stopped: 28/04/2014 16:51:23 ===
MSI (s) (50:E8) [16:51:23:228]: User policy value 'DisableRollback' is 0
MSI (s) (50:E8) [16:51:23:228]: Machine policy value 'DisableRollback' is 0
MSI (s) (50:E8) [16:51:23:228]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (50:E8) [16:51:23:228]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (50:E8) [16:51:23:228]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (50:E8) [16:51:23:228]: Restoring environment variables
MSI (s) (50:E8) [16:51:23:228]: Destroying RemoteAPI object.
MSI (s) (50:D4) [16:51:23:228]: Custom Action Manager thread ending.
MSI (c) (64:F4) [16:51:23:228]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: 5
MSI (c) (64:F4) [16:51:23:228]: MainEngineThread is returning 1603
=== Verbose logging stopped: 28/04/2014 16:51:23 ===
