Installation & Licensing
Installing Sketchbook Pro
1 REPLY 1
Sketchie
383 Views, 1 Reply
I just bought and downloaded Sketchbook pro.  It is a file named Autodesk_Sketchbook_Pro_v6_Multilingual_WIN_32bit
but there is no extension and I don't know what to do with it.  Should I rename it with a .exe extension?
Tags (1)
1 REPLY 1
aaronhai
in reply to: Sketchie
Hi Sketchie,
From your description, it sounds like you have enable Hide extenions for known file types under Windows Folder options here. You should see the .exe extension if you disable that option.
Generally, Autodesk_Sketchbook_Pro_v6_Multilingual_WIN_32bit.exe is the filename for Sketchbook Pro. You shoud be able to install by launching the file.
Thank you.
Aaron Hai
Administrator Productivity
