Installation & Licensing
Installing Service Pack 1 for Simulation Mechanical 2012
1 REPLY 1
DonaldR.Culp7481
201 Views, 1 Reply
I have re-installed Simulation Mechanical 2012 from the Autodesk CD. Checking Help\About shows:
Build 2012.00.00.0163 04-Mar-2011
I want to install Service Pack 1 per:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17244805&linkID=13806470
The readme file (http://images.autodesk.com/adsk/files/autodesk_simulation_2012_sp1_readme_enu.html#Installation_Inst..._) dated 6/15/2011 says:
"To verify the installation was successful, start Autodesk Simulation 2012. On the Help menu, select About. If the About box displays: Build 2011.01.01.nnnn, the installation was successful."
However, my CD build is already up to 2012, although the build date is only 04-Mar-2011.
I don't understand the build conflict. Should I install SP1?
Don Culp
1 REPLY 1
I would run the update.  The installer should detect if the update will apply to the installed version of the software on your computer.
David Lau
Administrator Productivity
