Im a student and I tried to install revit student version.
My laptop specifications.
10 gb ssd free
900 gb hdd free
Nvidea
i7 3630QM
I did the browser install. Didn't install
the full download en then installing en everytime it doenst work.
I give in my product information en then it goes to installing screen en then it says its ready. but it didn't install anything.
First after giving my product information a get this.
After I press install I get this (every disk I install. This one is ssd, I have on with 900 gb hdd same happens.
I hope somebody can help my
Rico
DarrenP
After a lot of text i dont understand.
FailedInstallation aborted, Result=1603. This code stands behind everyting.
DarrenP
Thank you
The installing is faling because InstallMicrosoft Visual C++ 2010 SP1 Redistributable (x86)....
The strange thing is that InstallMicrosoft Visual C++ 2010 SP1 Redistributable (x86) isnt installed on my laptop. 2008 a bunch of and 1: 2012 (2012 deleted because is newer) didnt work.
I realy don't get it.
You need to uninstall Microsoft Visual C++ 2010 SP1 Redistributable because Revit needs to install an earlier version of C++ 2010. After you uninstall it, you should be able to complete the Revit installation, which an earlier version of C++ will also be installed (required for the installation of Revit 2013).
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Hello. Uninstall ALL Microsoft C++ entries and I would also uninstall Microsoft NET as well. After these are gone, reboot, log in as an Admin and turn off your Antivirus or any blockers. Then run an install.
Thank you for taking part in our community!
