When I try to install the Revit 14 30-day trial, I click on the .exe file and agree to the terms and then nothing happens. Can someone help?
Are you attempting to use the online trial of the full download trial? Also, if you're running windows xp, it will not install because its no longer supported.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
That's odd indeed.
You might try downloading from Matt, the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Make sure you are installing with local admin rights, UAC off, and anti-virus temporarily disabled. You might even want to login as another user with local admin rights and/or install in diagnostic mode.
Good Luck!
