Installation & Licensing
*McNeely, Jack
Message 1 of 5 (93 Views)
Installing New ADLM
93 Views, 4 Replies
08-28-2000 08:29 AM
I am using the original installation of ADLM from acad R14 and figured it's
time to upgrade before installing 2000i -based software. The ADLM issues
licenses for a 2-node LDDT network and a 3- node ADDT network. Do I
uninstall the original ADLM first or will the new ADLM software recognize
the old and upgrade it in the same directory? I don't want to re-authorize
all my network software if it can be avoided. Also, is there a source for a
list of feature codes and the associated software(e.g. 140= Acad R14,
150=ACAD 2K, etc.) Any help would be appreciated. Thank You,
Jack McNeely
jack.mcneely@emh2.mccoy.army.mil
*Nehls, Kevin
Message 2 of 5 (93 Views)
Re: Installing New ADLM
08-28-2000 09:26 AM in reply to: *McNeely, Jack
Jack,
I believe that if you install the new AdLM over the old (if that is
possible) that you will have to reauthorize everything anyway. One way that
you can do this is to install the new AdLM on a different server and keep
the old one running until you get all of your codes reauthorize, then you
take down the old server, bring up the new server, reset the ACADSERVER
variable on each of the client machines and have them log back into AutoCAD.
I don't know if there is a better way or not, but that is probably how I
would do it.
You can get the list of product codes off of you AutoCAD CD. Just do a
search for NLMPROD.LST and copy that over the existing one. If you can't
find it then I can post my list from my 2000i mechanical CD. Jerry also
posted a link to an online list awhile back, but we ended pointing out that
it was rather out of date. I believe that they updated the list but who
knows if it has the new 2000i codes.
Kevin Nehls
remove -ns- for direct reply
On the other hand, you have fingers.
"Jack McNeely" wrote in message
news:7545CCC164762EFD732B8DD674FB5462@in.WebX.SaUCah8kaAW...
Jack McNeely
*McNeely, Jack
Message 3 of 5 (93 Views)
Re:
08-28-2000 11:09 AM in reply to: *McNeely, Jack
So how do you re-authorize?. I have to use the same server as the old ADLM.
After I install the new ADLM, is it a simple matter of keying in the
original auth codes?
Kevin Nehls wrote in message ...
*Nehls, Kevin
Message 4 of 5 (93 Views)
Re:
08-28-2000 11:35 AM in reply to: *McNeely, Jack
Since you don't have the luxury of using a different computer as a new AdLM
server your best bet is to wait until the users are not using AutoCAD. Then
write down the current server code. Now uninstall the old AdLM (reboot if
necessary) and install the new AdLM (reboot if necessary). Now look at the
server code. If it is the same as the old server code your in phat city,
just enter in your old auth codes. If it is different then you will have to
give the auth code call center a call.
Here is the 800 number: 1-800-551-1490. Personally, I've never had a
problem calling the auth code center, just put your phone on speaker phone
and wait for a rep to pickup on the other line. Be sure to have your new
server code, as well as the serial numbers for your AutoCAD seats and
license packs (if you have any license packs).
I hope this helps.
Kevin Nehls
*Hänninen, Juha
Message 5 of 5 (93 Views)
08-30-2000 10:46 PM in reply to: *McNeely, Jack
I updated the ADLM software and the program found the old R14 authorization
code and worked OK.
What I did,
1. got authorization code for 2000i
- checked
- old server code:
- serial No:
- CDKey:
- the old serial number of our R14:
2. waited till evening, warned possible users
3. stopped ADLM
4. updated ADLM
5. started ADLM again
6. added 2000i feature key and authorization code
Autodesk should send a proper installation guide with 2000i
Juha Hänninen
Jaakko Pöyry Oy
it's
a
> Jack McNeely
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
