I am having a problem installing MDT 2009 on my machine with an existing Inventor 2012 license.
I run into a "fatal fault" which, by the log file, is due to reason "1603".
I have tried everything here:
http://forums.autodesk.com/t5/Installation-Licensing/MDT2009-install/td-p/3131470
That is, i'm using the latest installer, there are no previous directories installed, and i made sure to unzip both disks in the same folder.
Attached is the larger log from my failed installation.
Any help would be MUCH appreciated.
Josh
You've download the last version of MDT 2009 from here?
http://usa.autodesk.com/adsk/servlet/pc/item?id=13744274&siteID=123112
1603 is pretty generic. You do realize this program is no longer supported and has been retired, right?
