Matt -
I've always wanted to try this anyway, so let's give it a go...
You said that you got it to install on another machine right??? Take all the files and folders in the c:\FlexLM folder (Assuming
that's where you installed it) and copy them to c:\FlexLM on the machine that you want to be the license server. Run lmtools.exe and
continue just like the instructions say. Post back and let me know what happens (anything added to the registry (that is important)
is done when the flexlm service is set up, not at install time).
Warning: I don't know that this will work, but I just moved our adlm. I'd had some of the old adlm tools already installed on the
machine where I was putting adlm and the install seemed to fail (like yours). I just copied the files from the old machine and all
was well. No guarantee!!
jason martin
frankfurt-short-bruza
Member of the Autodesk Discussion Forum Moderator Program
"Matt Sparks" wrote in message news:86034C8BD81995D2C2D0F1705CC14FC7@in.WebX.maYIadrTaRb...
> Check all of those, it seems as though it is unable to install. Similar
> when you try an silent install and it flashes, with no error messages unless
> you have the error log enabled.
