Please see attached image: issue_dwg-viewer.jpg
After installing the software I'm left with these maps.
And files without extension.
Any suggestions/ ideas what to do or what went wrong?
Thank you for using Autodesk Discussion Forums.
I just tested installer for 64-bit DWG TrueView Download (the link is below) and it worked fine.
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=9078813
Please try reinstalling the program as follows:.
1.Log on with your local system admin account
2.Rename C:\Autodesk\DWGTrueViewx64InstallImage folder (this is the default location of Trueview installation content) from your previous installation
3.Disable your antivirus software.
Note: if your OS is Windows 7, please also disable UAC (User Access Control Manager)
http://windows.microsoft.com/en-CA/windows-vista/Turn-User-Account-Control-on-or-off
4. Download DWG TrueView 2013 installer from the link above
5.Complete DWG TrueView 2013 installation
