Installation & Licensing
Installing AutoCad LT 2008 in Windows Vistas
3 REPLIES 3
332 Views, 3 Replies
On July 09, 2014 when I booted my computer I was met with the “ICE” virus which eventually erased my hard drive.
I have a Dell XPS 410 desktop computer running Vistas Home Premium with Service Pack 2.
After Using the Dell Restore to Factory Settings which included re-formatting the hard drive, I reinstalled all of my software including all Windows Vistas Updates.
The problem I am having is when I try to install Autocad LT 2008 I do the following.
I insert6 the AutoCad Lt 2008 disk into drive “F” and click on Run Setup.exe, then the Setup Initialization popup comes up, I get another popup called Setup.exe – no disk which states that there is no disk in the drive. Please insert a disk into drive\Device\Hsrddisk\DR2.
By clicking on cancel 8 times the Installation Wizard comes up and I click on Install Products. On the next Installation Wizard screen I click on next.
On the next Installation Wizard screen I accept the license agreement and click on next.
On the next installation Wizard I put in my name and organization and click next.
On the next Installation Wizard I click on configure, then Install.
The next Installation Wizard comes up tellinf me that it is installing MSXML 6 and Autocad LT 2008.
The next Installation Wizard screen comes up stating that the installation is complete and “succeeded”. At this point I click Finish and the program returns to the desktop hwere the AutoCad Lt 2008 icon has been installed.
When I click on the Icon a popup appears “Migrate Custom Settings” at this point I click on OK and get a popup “verifying License” and another popup appears which states that the AutoCad Application has stopped working and that Windows will close the program and notify me if a solution is available.
I then click on close program and the popup disappears.
This installation has always worked prior to this.
ANYONE HAVE ANY IDEAS AS TO WHAT IS HAPPENING HERE???
William Hepler
whepler@lumos.net
3 REPLIES 3
TravisNave
I would do a reinstall by copying the files to your hard drive, then install from there with admin rights, UAC off, and anti-virus temporarily disabled.  Your LT 2008 should work on Vista.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
After I filed that report asking for help, I decided that I would do some a "first things first" maintenance on the computer. I started uninstalling some web browsing programs, one by one and booting AutoCad LT 2008 after each un-installation. I had un-installed one of them and booted ACAD Lt, it didn't work, when I installed the second one (Google Chrome) and booted AutoCad LT, IT WORKED and I was able to activate the product and it now works fine. Thanks for your reply, I had already copied all the files to the "C" drive but that didn't work, either. I really appreciate your feedback, though.
Whepler
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
TravisNave
Excellent. Thanks for the update. Having IE as the default browser for
activation is definitely a must. Thanks for reiterating that. Good job!
Autodesk Forums:
Administrator Productivity
