• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    NicoleBorsh
    Installing AutoCAD Map 2008 on a Windows 7, 32 bit machine
    1381 Views, 3 Replies
    04-15-2011 01:20 PM
    Can AutoCAD Map 2008 be installed on a Windows 7, 32 bit machine?  I have 2 users still on 2008.  They are not heavy users so no plans to upgrade, but now one user had his machine rebuilt and Windows 7 was put on.  I have found that 2008 can be installed on Vista 32 bit, but looking for information on installing it on Windows 7 32 bit.
    Thank you.
    Please use plain text.
    DarrenP
    Re: Installing AutoCAD Map 2008 on a Windows 7, 32 bit machine
    04-15-2011 01:30 PM in reply to: NicoleBorsh
    it may install on windows 7 but it is not supported on windows 7
    so you may run into issues since 2008 came out before windows 7 came out
    here is a list of autodesk products supported on windows 7: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14185352
    New Member
    NicoleBorsh
    04-15-2011 01:43 PM in reply to: DarrenP
    Thank you.  We will give it a try then.
    Distinguished Contributor
    09-27-2011 05:28 PM in reply to: NicoleBorsh
    Just wanted to add my 2 cents on this and log a fix in case I need to search for it again.
    When I tried installing Map 2008 on a Win7 32-bit box, I ran into an error code:
    When I tried running it from a deployment shortcut, it would roll back the installation toward the end.  So I ran the install from the Setup.exe directly so it would not do a silent install.  Now I could see what was going on.  Got Error message:
     Error 1935. An error occurred during the installation of assembly 'Microsoft.VC80.CRT,type="win32",processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.42"'. Please refer to Help and Support for more information.
    Doing some digging, I found that the problem seemed to be with the version of Visual C++.  I ran Microsoft Visual C++ 2005 SP1 and that seemed to fix the problem.
