Installation & Licensing
Installing AutoCAD Civil 3D 2014
3 REPLIES 3
dpngo25
5653 Views, 3 Replies
So I have windows 8 and I am trying to install autocad Civil 3D 2014. I input my serial number and product key and that goes well.
So now I put in the installation path to "C:\Program Files\Autodesk\" and click install. Then an error message that states "AutoCAD civil 3D 2014 or map 3D 2014 must be installed for storm and sanitary analysi 2014 to be installed." pops up.
And so click the installation log file and this is what I get:
2013/8/15:12:02:52 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:12:02:52 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:12:02:52 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_wi_en-us
2013/8/15:12:02:52 Paul Ngo PAU_PC Launch
2013/8/15:12:02:52 Paul Ngo PAU_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/Autodesk_C3D_2014_English_Win_64bit_wi_... /SN 900-31126596 /PK 237F1 /student /skipEULA /akamai /auth /sid
2013/8/15:12:02:52 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AIA4C3.tmp
2013/8/15:12:04:32 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:12:03:00 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:12:03:00 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:12:03:00 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AIA4C3.tmp
2013/8/15:12:03:00 Paul Ngo PAU_PC Launch
2013/8/15:12:03:36 Paul Ngo PAU_PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:12:04:32 Paul Ngo PAU_PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:12:04:32 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AIA4C3.tmp\Setup\AcSetup.dll
2013/8/15:12:04:32 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:12:04:32 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:13:42:25 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:13:42:25 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:13:42:25 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_wi_en-us
2013/8/15:13:42:25 Paul Ngo PAU_PC Launch
2013/8/15:13:42:25 Paul Ngo PAU_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/Autodesk_C3D_2014_English_Win_64bit_wi_... /SN 900-31126596 /PK 237F1 /student /skipEULA /akamai /auth /sid
2013/8/15:13:42:25 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI92F7.tmp
2013/8/15:13:42:33 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:13:42:31 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:13:42:31 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:13:42:31 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI92F7.tmp
2013/8/15:13:42:31 Paul Ngo PAU_PC Launch
2013/8/15:13:42:32 Paul Ngo PAU_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:13:42:33 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AI92F7.tmp\Setup\AcSetup.dll
2013/8/15:13:42:33 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:13:42:33 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:13:44:40 Paul Ngo PAU_PC PageOpen LicenseDialog
2013/8/15:13:44:40 Paul Ngo PAU_PC PageOpen ProductInfoDialog
2013/8/15:13:44:40 Paul Ngo PAU_PC PageOpen ProductSelectionDialog2
2013/8/15:13:44:55 Paul Ngo PAU_PC PageOpen FullProgressDialog
2013/8/15:13:44:56 Paul Ngo PAU_PC Download Play SSA http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:13:51:15 Paul Ngo PAU_PC Download Complete SSA http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:13:51:15 Paul Ngo PAU_PC Installing Autodesk Storm & Sanitary Analysis: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";{F49CAD53-8F0F-441A-B974-CA5C3D7D03C1},Autodesk AutoCAD Civil 3D 2014 32 bit Object Enabler,;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/15:13:51:24 Paul Ngo PAU_PC Install Autodesk Storm & Sanitary Analysis Failed Installation aborted, Result=1603
2013/8/15:13:51:27 Paul Ngo PAU_PC PageOpen InstallCompleteDialog
2013/8/15:13:51:37 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:14:11:01 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:14:11:01 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:14:11:01 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_wi_en-us
2013/8/15:14:11:01 Paul Ngo PAU_PC Launch
2013/8/15:14:11:01 Paul Ngo PAU_PC CommandLine /URL "http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/Autodesk_C3D_2014_English_Win_64bit_wi_... /skipPI /SN 900-31126596 /PK 237F1 /akamai
2013/8/15:14:11:01 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI6CDF.tmp
2013/8/15:14:12:15 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:14:11:06 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:14:11:06 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:14:11:06 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI6CDF.tmp
2013/8/15:14:11:06 Paul Ngo PAU_PC Launch
2013/8/15:14:12:15 Paul Ngo PAU_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:14:12:15 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AI6CDF.tmp\Setup\AcSetup.dll
2013/8/15:14:12:15 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:14:12:15 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:14:13:43 Paul Ngo PAU_PC PageOpen LicenseDialog
2013/8/15:14:14:10 Paul Ngo PAU_PC PageOpen ProductInfoDialog
2013/8/15:14:14:10 Paul Ngo PAU_PC PageOpen ProductSelectionDialog2
2013/8/15:14:14:20 Paul Ngo PAU_PC PageOpen FullProgressDialog
2013/8/15:14:14:20 Paul Ngo PAU_PC Download Skipped SSA http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:14:14:20 Paul Ngo PAU_PC Installing Autodesk Storm & Sanitary Analysis: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";{F49CAD53-8F0F-441A-B974-CA5C3D7D03C1},Autodesk AutoCAD Civil 3D 2014 32 bit Object Enabler,;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/15:14:14:29 Paul Ngo PAU_PC Install Autodesk Storm & Sanitary Analysis Failed Installation aborted, Result=1603
2013/8/15:14:14:34 Paul Ngo PAU_PC PageOpen InstallCompleteDialog
2013/8/15:14:15:24 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:14:20:48 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:14:20:48 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:14:20:48 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_wi_en-us
2013/8/15:14:20:48 Paul Ngo PAU_PC Launch
2013/8/15:14:20:48 Paul Ngo PAU_PC CommandLine /URL "http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/Autodesk_C3D_2014_English_Win_64bit_wi_... /skipPI /SN 900-31126596 /PK 237F1 /akamai
2013/8/15:14:20:48 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI6429.tmp
2013/8/15:14:20:51 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:14:20:49 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:14:20:49 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:14:20:49 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI6429.tmp
2013/8/15:14:20:49 Paul Ngo PAU_PC Launch
2013/8/15:14:20:50 Paul Ngo PAU_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/...
2013/8/15:14:20:50 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AI6429.tmp\Setup\AcSetup.dll
2013/8/15:14:20:50 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:14:20:51 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:14:20:58 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:15:51:28 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:15:51:28 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:15:51:28 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm
2013/8/15:15:51:28 Paul Ngo PAU_PC Launch
2013/8/15:15:51:28 Paul Ngo PAU_PC CommandLine
2013/8/15:15:51:28 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI2C3F.tmp
2013/8/15:15:51:52 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:15:51:41 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:15:51:41 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:15:51:41 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI2C3F.tmp
2013/8/15:15:51:41 Paul Ngo PAU_PC Launch
2013/8/15:15:51:42 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AI2C3F.tmp\Setup\AcSetup.dll
2013/8/15:15:51:42 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:15:51:52 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:15:59:43 Paul Ngo PAU_PC PageOpen LicenseDialog
2013/8/15:15:59:46 Paul Ngo PAU_PC PageOpen ProductInfoDialog
2013/8/15:16:00:11 Paul Ngo PAU_PC PageOpen ProductSelectionDialog2
2013/8/15:16:00:19 Paul Ngo PAU_PC PageOpen FullProgressDialog
2013/8/15:16:00:19 Paul Ngo PAU_PC Installing Autodesk Storm & Sanitary Analysis: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";{F49CAD53-8F0F-441A-B974-CA5C3D7D03C1},Autodesk AutoCAD Civil 3D 2014 32 bit Object Enabler,;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/15:16:00:26 Paul Ngo PAU_PC Install Autodesk Storm & Sanitary Analysis Failed Installation aborted, Result=1603
2013/8/15:16:00:29 Paul Ngo PAU_PC PageOpen InstallCompleteDialog
2013/8/15:16:01:48 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:16:21:20 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:16:21:20 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:16:21:20 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm
2013/8/15:16:21:20 Paul Ngo PAU_PC Launch
2013/8/15:16:21:20 Paul Ngo PAU_PC CommandLine
2013/8/15:16:21:20 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI8355.tmp
2013/8/15:16:21:32 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:16:21:25 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:16:21:25 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:16:21:25 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI8355.tmp
2013/8/15:16:21:25 Paul Ngo PAU_PC Launch
2013/8/15:16:21:26 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AI8355.tmp\Setup\AcSetup.dll
2013/8/15:16:21:26 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:16:21:32 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:16:21:35 Paul Ngo PAU_PC PageOpen LicenseDialog
2013/8/15:16:21:38 Paul Ngo PAU_PC PageOpen ProductInfoDialog
2013/8/15:16:22:00 Paul Ngo PAU_PC PageOpen ProductSelectionDialog2
2013/8/15:16:22:07 Paul Ngo PAU_PC PageOpen FullProgressDialog
2013/8/15:16:22:07 Paul Ngo PAU_PC Installing Autodesk Storm & Sanitary Analysis: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";{F49CAD53-8F0F-441A-B974-CA5C3D7D03C1},Autodesk AutoCAD Civil 3D 2014 32 bit Object Enabler,;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/15:16:22:16 Paul Ngo PAU_PC Install Autodesk Storm & Sanitary Analysis Failed Installation aborted, Result=1603
2013/8/15:16:22:19 Paul Ngo PAU_PC PageOpen InstallCompleteDialog
2013/8/15:16:24:04 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:16:25:43 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:16:25:43 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:16:25:43 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm
2013/8/15:16:25:43 Paul Ngo PAU_PC Launch
2013/8/15:16:25:43 Paul Ngo PAU_PC CommandLine
2013/8/15:16:25:43 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI8517.tmp
2013/8/15:16:25:53 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:16:25:44 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:16:25:44 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:16:25:44 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI8517.tmp
2013/8/15:16:25:44 Paul Ngo PAU_PC Launch
2013/8/15:16:25:45 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AI8517.tmp\Setup\AcSetup.dll
2013/8/15:16:25:45 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:16:25:52 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:16:26:09 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:16:30:01 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:16:30:01 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:16:30:01 Paul Ngo PAU_PC Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm
2013/8/15:16:30:01 Paul Ngo PAU_PC Launch
2013/8/15:16:30:01 Paul Ngo PAU_PC CommandLine
2013/8/15:16:30:01 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI76EA.tmp
2013/8/15:16:30:10 Paul Ngo PAU_PC === Setup ended ===
2013/8/15:16:30:02 Paul Ngo PAU_PC === Setup started on PAU_PC by Paul Ngo ===
2013/8/15:16:30:02 Paul Ngo PAU_PC Path_Length: 152
2013/8/15:16:30:02 Paul Ngo PAU_PC Current Directory C:\Users\PAULNG~1\AppData\Local\Temp\_AI76EA.tmp
2013/8/15:16:30:02 Paul Ngo PAU_PC Launch
2013/8/15:16:30:02 Paul Ngo PAU_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PAULNG~1\AppData\Local\Temp\_AI76EA.tmp\Setup\AcSetup.dll
2013/8/15:16:30:02 Paul Ngo PAU_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/8/15:16:30:10 Paul Ngo PAU_PC PageOpen LaunchDialog
2013/8/15:16:30:14 Paul Ngo PAU_PC PageOpen LicenseDialog
2013/8/15:16:30:16 Paul Ngo PAU_PC PageOpen ProductInfoDialog
2013/8/15:16:32:26 Paul Ngo PAU_PC PageOpen ProductSelectionDialog2
2013/8/15:16:33:22 Paul Ngo PAU_PC PageOpen FullProgressDialog
2013/8/15:16:33:22 Paul Ngo PAU_PC Installing Autodesk Storm & Sanitary Analysis: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";{F49CAD53-8F0F-441A-B974-CA5C3D7D03C1},Autodesk AutoCAD Civil 3D 2014 32 bit Object Enabler,;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/8/15:16:34:42 Paul Ngo PAU_PC Install Autodesk Storm & Sanitary Analysis Failed Installation aborted, Result=1603
Thanks for the help. :]
3 REPLIES 3
dpngo25
in reply to: dpngo25
So I deleted  and uninstalled everything and the same thing happened. Also, it said that the storm analysis cannot be installed without autocad civil but right before,  that happened, it said that my autocad civil was already installed... so Ido not know 😞
TravisNave
Do a clean uninstall of Civil and make sure it installs correctly.  Sometimes a failed install gets stuck and thinks it is installed.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Good Luck!
Autodesk Forums:
dpngo25
in reply to: TravisNave
There must have been something wrong with the uninstallation because I ran the "Diagnose and Fix" thing to uninstall it, and then made sure it was completely reuninstalled, and then tried reinstalling again and it worked!
Thank you so much for the help! Now I will not fail my design class 😄
Administrator Productivity
