Installation & Licensing
Installing 3dmax 2012 activation issue Please Help..
2 REPLIES 2
man1998
839 Views, 2 Replies
ok here it is... ???
Autodesk 3dmax 2012
It says i have a number.. ok
But I try to activate it and it wont let me??
I have tried to get it activated but it wont let me
So how do i activate it????
Edited by
Discussion_Admin
2 REPLIES 2
TravisNave
in reply to: man1998
Please do not ever post your serial numbers on a public site.  In the event that you cannot delete the images in a timely fashion, I have asked the discussion administrator to do so.
As for your activation, please call Autodesk Activations directly and give them your request code on the screen.  They will be able to provide you with an activation code manual that you can copy/paste in.
Please call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > Stand-alone
Good Luck.
Autodesk Forums:
philip.s
Hi man1998,
Following up to see if you're still unable to a activate your 3ds Max 2012 software? If so, can you please elaborate as to what's preventing you from activating. Are you unable to proceed past the screen above, is there an additional error message etc...
Administrator Productivity
