Installation & Licensing
416 Views, 6 Replies
Installation
I started up the Inventor 2013 installer and when it gives you options of which programs to install, there is a notification that says I need to install a Windows Vista hotfix (KB971138).  I went and found and and installed the hotfix but when i restarted the Inventor installer, the same notification was present.  A picture is attached, showing the notification.  Any ideas or solutions?
System:
Compaq Presario CQ60
Memory-2GB
Processor-AMD Athlon Dual-Core QL-62 2.00 GHz
Windows Vista Home Premium
6 REPLIES 6
Paul-Mason
REBOOT Your system and run the Inventor Installer.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Tags (1)
Thanks for the idea.  I just tried rebooting, but unfortunately the same notification came up when I started the installer.
TravisNave
Vista is not a supported OS for Autodesk 2013 products.  You may not be able to install it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Paul-Mason
in reply to: TravisNave
Don't know where you got that from as according to http://usa.autodesk.com/autodesk-inventor/system-requirements/ IV 2013 WILL run on Vista
BUT it could possibly be note 9 that you need to read and find out about
Inventor 2013 has been optimized to take advantage of the SSE2 extended instruction sets supported on Pentium 4, AMD Athlon 64, and AMD Opteron processors. Inventor 2013 will not install on computers that do not support SSE2. Several utilities are available on the Internet that report CPUID, including supported instructions sets.
To check your syster ther is a freware program at http://www.cpuid.com/downloads/cpu-z/1.60.1-setup-en.exe
Inventor 2023 Pro
HP Z420 workstation
TravisNave
in reply to: Paul-Mason
Vista is not a supported OS as Autodesk has removed support for Vista for the 2013 product line. The link you provided shows that only Windows XP and Windows 7 are supported platforms. Believe it or not, it's my job to know these things. Thanks.
Autodesk Forums:
TravisNave
Here is the official Autodesk FAQ regarding Vista no longer being supported as of January 1, 2012.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18424371
Autodesk Forums:
Administrator Productivity
