Installation & Licensing
Installation problems
5 REPLIES 5
1095 Views, 5 Replies
Hi @ all,
i really hope someone can help me.
I'm stucked during the initialization process few second l8r the double clicking of setup.exe
I'm trying to install Acad 12 on a new personal computer in our company but i always get the same error.
"Unable to open the device or the specified file c:\temp\...\.. ..\ads2012\SetupDesignReview2012.msi"
I've tryied reinstalling all .net and visual c++ software but nothing.
I tried also setting the temp dir outside the "user" directory but nothing.
Anyone can help me pls?
Thank you
Bob
5 REPLIES 5
  I have the same problem on map3d 2013 e autocad LT 2014 downloaded or installed directly from the subscription center.
 Thanks Fabio
TravisNave
If another downloaded copy doesn't work for you, try installing without Design Review checked.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Thank you for you answer but the error comes out during the inizialization process.
I cant reach the setup menu.
1) i put in the dvd;
2) i wait 5/10 seconds (inizialization)
3) and then comes out the error.
I cant reach the menu where i can choose what i need to install.
Is it possible to force the inizialization process ang start by choosing the product i need?
Thank you
I solved my problem disabling the antivirus (trendmicro)
Thank you very much. Tou made my day 😄
Joking a part thank you.
I tried everything but the Trendmicro...
Thank you.
Solved
Administrator Productivity
