• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Installation problem
    149 Views, 5 Replies
    11-11-2012 01:41 PM
    So i am a student who just recently made an account and i am downloading AutoCAD 2012, or trying to.
    I download the free student version from Autodesk and that goes well. Then I go through the installation process which goes well and successful too. but i cant find the application to run the program. It just isn't there. I think there was a problem in the installation process. What should/can I do? WHat should I double-check?
    Please use plain text.
    philip.s
    Re: Installation problem
    11-12-2012 03:56 PM in reply to: r4bliss
    Hello Rishab and welcome to the community!
    Have you searched in your local hard drive -> program files -> Autodesk folder? If there is nothing there, you can check your installation log to see if it completed or failed.
    Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    *Expert Elite*
    LisaDrago
    11-12-2012 05:25 PM in reply to: philip.s
    Hello - I am helping one of my students with this issue - but it is with Revit Arch 2013.
    We ran throught the install and it says it is installed. but in the program listing it is not there. I have attached a few images. I am not sure where else to look.
    When I put the disk in to install it I cannot because it thinks it is installed.
    It was installed with admin rights.
    Any help would be appriciated.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    philip.s
    11-12-2012 10:06 PM in reply to: LisaDrago
    Hi Lisa,
    Did you check the installation log as well? If that doesn't provide any value, you may want to consider performing a clean uninstall and trying again.
    Philip Schmelzer
    TW | PI | YT | BLOG
    *Expert Elite*
    LisaDrago
    11-13-2012 06:23 AM in reply to: philip.s
    Hello Phiip - yes, i ran throught the log files. Did not provide any info.
    My thought was a clean uninstall  - just wanted to double check and make sure I wasn't not missing something.
    I will let you know the results.
    Thank you!
    LD
    *Expert Elite*
    DarrenP
    11-13-2012 07:38 AM in reply to: LisaDrago
    try running ccleaner on that machine
