• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Installation problem !!
    1511 Views, 5 Replies
    03-28-2012 09:51 PM
    Try to install revit structure 2012 but could not install....
    got this error message.
    2012/3/29:00:01:30    Arbin    ARBIN-PC    === Setup started on ARBIN-PC by Arbin ===
    2012/3/29:00:01:30    Arbin    ARBIN-PC    Launch
    2012/3/29:00:03:49    Arbin    ARBIN-PC    === Setup ended ===
    2012/3/29:00:01:34    Arbin    ARBIN-PC    === Setup started on ARBIN-PC by Arbin ===
    2012/3/29:00:01:34    Arbin    ARBIN-PC    Launch
    2012/3/29:00:03:51    Arbin    ARBIN-PC    PageOpen    LaunchDialog
    2012/3/29:00:04:26    Arbin    ARBIN-PC    PageOpen    LicenseDialog
    2012/3/29:00:04:29    Arbin    ARBIN-PC    PageOpen    ProductInfoDialog
    2012/3/29:00:04:44    Arbin    ARBIN-PC    PageOpen    ProductSelectionDialog2
    2012/3/29:00:04:58    Arbin    ARBIN-PC    PageOpen    FullProgressDialog
    2012/3/29:00:04:58    Arbin    ARBIN-PC    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Structure_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Arbin\AppData\Local\Temp\vcredist_x86_2010.log
    2012/3/29:00:05:05    Arbin    ARBIN-PC    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
    2012/3/29:00:05:06    Arbin    ARBIN-PC    PageOpen    InstallCompleteDialog
    2012/3/29:00:06:16    Arbin    ARBIN-PC    === Setup ended ===
    2012/3/29:00:13:01    Arbin    ARBIN-PC    === Setup started on ARBIN-PC by Arbin ===
    2012/3/29:00:13:01    Arbin    ARBIN-PC    Launch
    2012/3/29:00:13:09    Arbin    ARBIN-PC    === Setup ended ===
    2012/3/29:00:13:09    Arbin    ARBIN-PC    PageOpen    LaunchDialog
    2012/3/29:00:13:49    Arbin    ARBIN-PC    PageOpen    LicenseDialog
    2012/3/29:00:13:56    Arbin    ARBIN-PC    PageOpen    ProductInfoDialog
    2012/3/29:00:14:18    Arbin    ARBIN-PC    PageOpen    ProductSelectionDialog2
    2012/3/29:00:14:44    Arbin    ARBIN-PC    PageOpen    FullProgressDialog
    2012/3/29:00:14:44    Arbin    ARBIN-PC    Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Structure_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Arbin\AppData\Local\Temp\vcredist_x86_2010.log
    2012/3/29:00:14:49    Arbin    ARBIN-PC    Install    Microsoft Visual C++ 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
    what to do now..do I have to format my computer..or there is any way...????
    help me
    Please use plain text.
    Product Support
    Re: Installation problem !!
    03-29-2012 08:40 AM in reply to: arbinpradhan
    Hi arbinprdhan;
       It looks like the installation is failing on the Visual C++ 2010. Most likely you have it currently installed and it's simply not allowing you to progress. Remove the current VC ++ 2010 installation via Add/Remove programs and try again. The
    Dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    03-29-2012 10:58 AM in reply to: Dwayne.Poot
    \ASR\RVTMPB201200F_EL_Adlm.asr
    Extracting x64\RAC2012\Common Application Data Folder\Autodesk\AdLM\ASR\RVTMPB201200F_EX_Adlm.asr
    Extracting x86\RAC2012\Common Application Data Folder\Autodesk\AdLM\ASR\RVTMPB201200F_EX_Adlm.asr
    Extracting x64\RAC2012\Common Application Data Folder\Autodesk\AdLM\ASR\RVTMPB201200F_FL_Adlm.asr
    Extracting x86\RAC2012\Common Application Data Folder\Autodesk\AdLM\ASR\RVTMPB201200F_FL_Adlm.asr
    Extracting x64\RAC2012\Common Application Data Folder\Autodesk\AdLM\ASR\RVTMPB201200F_TL_Adlm.asr
    Extracting x86\RAC2012\Common Application Data Folder\Autodesk\AdLM\ASR\RVTMPB201200F_TL_Adlm.asr
    Extracting 3rdParty\DirectX\Apr2005_d3dx9_25_x64.cab
    Extracting 3rdParty\DirectX\Apr2005_d3dx9_25_x86.cab
    Extracting 3rdParty\DirectX\Apr2006_d3dx9_30_x64.cab
    Extracting 3rdParty\DirectX\Apr2006_d3dx9_30_x86.cab
    Extracting 3rdParty\DirectX\Apr2006_MDX1_x86.cab
    Extracting 3rdParty\DirectX\Apr2006_MDX1_x86_Archive.cab
    Extracting 3rdParty\DirectX\Apr2006_XACT_x64.cab
    Extracting 3rdParty\DirectX\Apr2006_XACT_x86.cab
    Extracting 3rdParty\DirectX\Apr2006_xinput_x64.cab
    Extracting 3rdParty\DirectX\Apr2006_xinput_x86.cab
    Extracting 3rdParty\DirectX\APR2007_d3dx10_33_x64.cab
    Extracting 3rdParty\DirectX\APR2007_d3dx10_33_x86.cab
    Extracting 3rdParty\DirectX\APR2007_d3dx9_33_x64.cab
    Extracting 3rdParty\DirectX\APR2007_d3dx9_33_x86.cab
    Extracting 3rdParty\DirectX\APR2007_XACT_x64.cab
    Extracting 3rdParty\DirectX\APR2007_XACT_x86.cab
    Extracting 3rdParty\DirectX\APR2007_xinput_x64.cab
    Extracting 3rdParty\DirectX\APR2007_xinput_x86.cab
    Extracting 3rdParty\DirectX\Aug2005_d3dx9_27_x64.cab
    Extracting 3rdParty\DirectX\Aug2005_d3dx9_27_x86.cab
    Extracting 3rdParty\DirectX\AUG2006_XACT_x64.cab
    Extracting 3rdParty\DirectX\AUG2006_XACT_x86.cab
    Extracting 3rdParty\DirectX\AUG2006_xinput_x64.cab
    Extracting 3rdParty\DirectX\AUG2006_xinput_x86.cab
    Extracting 3rdParty\DirectX\AUG2007_d3dx10_35_x64.cab
    Extracting 3rdParty\DirectX\AUG2007_d3dx10_35_x86.cab
    Extracting 3rdParty\DirectX\AUG2007_d3dx9_35_x64.cab
    Extracting 3rdParty\DirectX\AUG2007_d3dx9_35_x86.cab
    Extracting 3rdParty\DirectX\AUG2007_XACT_x64.cab
    Extracting 3rdParty\DirectX\AUG2007_XACT_x86.cab
    Extracting 3rdParty\DirectX\Aug2008_d3dx10_39_x64.cab
    Extracting 3rdParty\DirectX\Aug2008_d3dx10_39_x86.cab
    Extracting 3rdParty\DirectX\Aug2008_d3dx9_39_x64.cab
    Extracting 3rdParty\DirectX\Aug2008_d3dx9_39_x86.cab
    Extracting 3rdParty\DirectX\Aug2008_XACT_x64.cab
    Extracting 3rdParty\DirectX\Aug2008_XACT_x86.cab
    Extracting 3rdParty\DirectX\Aug2008_XAudio_x64.cab
    Extracting 3rdParty\DirectX\Aug2008_XAudio_x86.cab
    Extracting 3rdParty\DirectX\Aug2009_D3DCompiler_42_x64.cab
    Extracting 3rdParty\DirectX\Aug2009_D3DCompiler_42_x86.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dcsx_42_x64.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dcsx_42_x86.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dx10_42_x64.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dx10_42_x86.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dx11_42_x64.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dx11_42_x86.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dx9_42_x64.cab
    Extracting 3rdParty\DirectX\Aug2009_d3dx9_42_x86.cab
    Extracting 3rdParty\DirectX\Aug2009_XACT_x64.cab
    Extracting 3rdParty\DirectX\Aug2009_XACT_x86.cab
    Extracting 3rdParty\DirectX\Aug2009_XAudio_x64.cab
    Extracting 3rdParty\DirectX\Aug2009_XAudio_x86.cab
    Extracting Content\ADSKMaterials\2012\ILB\Autode~1.cab
    Extracting 3rdParty\DirectX\BDANT.cab
    Extracting 3rdParty\DirectX\BDAXP.cab
    Extracting Content\ADSKMaterials\2012\ILL\Common~1.cab
    Extracting Content\ADSKMaterials\2012\ILM\Common~1.cab
    CRC failed in Content\ADSKMaterials\2012\ILM\Common~1.cab
    Unexpected end of archive
    and a window appears saying' some of the files are corrupt please download a fresh copy. and i already did, but nothing works, what can i do. im using a mac, with VMware fusion. thanks
    Product Support
    03-29-2012 11:54 AM in reply to: cherrym_92
    Hi cherrym_92;
       There's a couple things that might be happening but most likely the download is still corrupt. I would try it on another machine if you have one.
    1. There's an anti-virus or security package preventing the extraction of the files.
    2. Confirm that the download isn't a 2 part download, I believe most of the Revit packages are 1 but if you are installing from a Suite they are generally 2 - 4 part installers.
    dwayne
    Dwayne Poot
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    12-29-2012 02:42 PM in reply to: arbinpradhan
    when i extract thee 3d max the file autode~1.cab dosent extract then the installation dosent complete iwant this file please if any one has this file please send the link of this file to mohamed.mokhtar2009@hotmail.com
    thanks all
    New Member
    01-25-2013 03:34 PM in reply to: mohamed.mokhtar2009
    yesterday was my 1st day to see this post , Here u are
     u can check it on this link
    http://dc622.4shared.com/download/-WmB_2xy/Autode1.cab?tsid=20130125-233227-771455cd&dsid=3oh7jy.822...
