Installation & Licensing
r4bliss
338 Views, 5 Replies
Installation problem
So i am a student who just recently made an account and i am downloading AutoCAD 2012, or trying to.
I download the free student version from Autodesk and that goes well. Then I go through the installation process which goes well and successful too. but i cant find the application to run the program. It just isn't there. I think there was a problem in the installation process. What should/can I do? WHat should I double-check?
5 REPLIES 5
philip.s
in reply to: r4bliss
Hello Rishab and welcome to the community!
Have you searched in your local hard drive -> program files -> Autodesk folder? If there is nothing there, you can check your installation log to see if it completed or failed.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
LisaDrago
in reply to: philip.s
Hello - I am helping one of my students with this issue - but it is with Revit Arch 2013.
We ran throught the install and it says it is installed. but in the program listing it is not there. I have attached a few images. I am not sure where else to look.
When I put the disk in to install it I cannot because it thinks it is installed.
It was installed with admin rights.
Any help would be appriciated.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
philip.s
in reply to: LisaDrago
Hi Lisa,
Did you check the installation log as well? If that doesn't provide any value, you may want to consider performing a clean uninstall and trying again.
LisaDrago
Hello Phiip - yes, i ran throught the log files. Did not provide any info.
My thought was a clean uninstall  - just wanted to double check and make sure I wasn't not missing something.
I will let you know the results.
Thank you!
LD
DarrenP
try running ccleaner on that machine
DarrenP
Administrator Productivity
