Installation & Licensing
Active Member
paul.vdh93
Message 1 of 9 (367 Views)
Installation problem, autocad 2014 not available in installation config
367 Views, 8 Replies
11-20-2013 08:18 AM
How can I resolve this problem by the installation of autocad 2014 student?? I'm using Windows 8 64bits.
Thanks !
Paul
*Expert Elite*
DarrenP
Message 2 of 9 (358 Views)
Re: Installation problem, autocad 2014 not available in installation config
11-20-2013 08:50 AM in reply to: paul.vdh93
did you hover your mouse over the  icon?
it will tell you what the problem is
Darin.Green
Message 3 of 9 (356 Views)
11-20-2013 08:51 AM in reply to: paul.vdh93
I think you have a corrupted download or thumb drive. Try download a new copy of AutoCAD 2014 using the following link:
AutoCAD 64bit:
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
AutoCAD 32bit:
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
*Expert Elite*
DarrenP
Message 4 of 9 (336 Views)
11-20-2013 09:51 AM in reply to: Darin.Green
what was the problem?
Darin.Green
Message 5 of 9 (331 Views)
11-20-2013 09:57 AM in reply to: paul.vdh93
Paul,
It would be best to notify everyone of the issue as well as what solved it. Please post.
Darin
Darin Green
Active Member
paul.vdh93
Message 6 of 9 (329 Views)
11-20-2013 09:59 AM in reply to: Darin.Green
autocad 2013 was already installed, I had to uninstall it and reinstal 2014
Active Member
paul.vdh93
Message 7 of 9 (290 Views)
11-21-2013 12:08 AM in reply to: paul.vdh93
I uninstalled autocad 2013 and launched the installation of autocad 2014 but my internet connection broke during the installation so I tried a new installation but now I have the problem again .. I followed the procedure of this link http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 but it doesn't resolve my problem
Paul
Darin.Green
Message 8 of 9 (272 Views)
11-21-2013 07:05 AM in reply to: paul.vdh93
Paul,
Do you have any Autodesk products still installed? If so, uninstall everything and delete the following directories:
  • C:\Program Files\Autodesk
  • C:\Program Files\Common Files\Autodesk Shared
  • C:\Program Files (x86)\Autodesk
  • C:\Program Files (x86)\Common Files\Autodesk Shared
From the registry editor, delete the following:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk
Once you've done the items above, reboot the machine and download the media using the links in my earlier post and run the installation again.
For best practic, its recommended to install in the order of the product version (2013 --> 2014)
Darin Green
Product Support
dembkod
Message 9 of 9 (252 Views)
11-21-2013 12:08 PM in reply to: Darin.Green
paul.vdh93  ,
Hello. IN cases like this I usually recommend tke Microsoft Uninstall tool. It will clean out most corrupted installations.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Thank you for taking part in our community!
David Dembkoski
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
