How can I resolve this problem by the installation of autocad 2014 student?? I'm using Windows 8 64bits.
Thanks !
Paul
did you hover your mouse over the icon?
it will tell you what the problem is
DarrenP
I think you have a corrupted download or thumb drive. Try download a new copy of AutoCAD 2014 using the following link:
AutoCAD 64bit:
AutoCAD 32bit:
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution
what was the problem?
DarrenP
Paul,
It would be best to notify everyone of the issue as well as what solved it. Please post.
Darin
autocad 2013 was already installed, I had to uninstall it and reinstal 2014
Paul,
Do you have any Autodesk products still installed? If so, uninstall everything and delete the following directories:
From the registry editor, delete the following:
Once you've done the items above, reboot the machine and download the media using the links in my earlier post and run the installation again.
For best practic, its recommended to install in the order of the product version (2013 --> 2014)
Hello. IN cases like this I usually recommend tke Microsoft Uninstall tool. It will clean out most corrupted installations.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Thank you for taking part in our community!
