Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Installati on problem - Installati on aborted, Result=161 9
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi. I have an installation problem.
I am trying to install AutoCad 2012 on my MacBook Air (Windows 7 OS).
This is the install log:
2012/6/1:17:41:22 Manfredi MANFREDI-AIR === Setup started on MANFREDI-AIR by Manfredi === 2012/6/1:17:41:22 Manfredi MANFREDI-AIR Launch 2012/6/1:17:41:32 Manfredi MANFREDI-AIR === Setup ended === 2012/6/1:17:41:22 Manfredi MANFREDI-AIR === Setup started on MANFREDI-AIR by Manfredi === 2012/6/1:17:41:22 Manfredi MANFREDI-AIR Launch 2012/6/1:17:41:32 Manfredi MANFREDI-AIR PageOpen LaunchDialog 2012/6/1:17:41:45 Manfredi MANFREDI-AIR PageOpen LicenseDialog 2012/6/1:17:41:45 Manfredi MANFREDI-AIR PageOpen ProductSelectionDialog2 2012/6/1:17:41:57 Manfredi MANFREDI-AIR PageOpen LicenseDialog 2012/6/1:17:41:57 Manfredi MANFREDI-AIR PageOpen LaunchDialog 2012/6/1:17:42:07 Manfredi MANFREDI-AIR PageOpen LicenseDialog 2012/6/1:17:42:17 Manfredi MANFREDI-AIR PageOpen ProductInfoDialog 2012/6/1:17:42:43 Manfredi MANFREDI-AIR PageOpen ProductSelectionDialog2 2012/6/1:17:43:16 Manfredi MANFREDI-AIR PageOpen FullProgressDialog 2012/6/1:17:43:16 Manfredi MANFREDI-AIR Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_ x64_1040.exe /q 2012/6/1:17:44:03 Manfredi MANFREDI-AIR Install .NET Framework Runtime 4.0 Language Pack Succeeded 2012/6/1:17:44:03 Manfredi MANFREDI-AIR Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdPart y\DirectX\DXSETUP.exe /silent 2012/6/1:17:44:21 Manfredi MANFREDI-AIR Install DirectX Runtime Succeeded 2012/6/1:17:44:21 Manfredi MANFREDI-AIR Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian _Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/6/1:17:44:27 Manfredi MANFREDI-AIR Install FaroSDK Succeeded 2012/6/1:17:44:27 Manfredi MANFREDI-AIR Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian _Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/6/1:17:44:40 Manfredi MANFREDI-AIR Install Autodesk Material Library 2012 Succeeded 2012/6/1:17:44:40 Manfredi MANFREDI-AIR Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian _Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/6/1:17:45:03 Manfredi MANFREDI-AIR Install Autodesk Material Library 2012 - Low Resolution Succeeded 2012/6/1:17:45:03 Manfredi MANFREDI-AIR Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdPart y\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v R:\Temp\vcredist_x86_2005.log"" " 2012/6/1:17:45:04 Manfredi MANFREDI-AIR Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2012/6/1:17:45:19 Manfredi MANFREDI-AIR Rollback Autodesk Material Library 2012 - Low Resolution Succeeded 2012/6/1:17:45:32 Manfredi MANFREDI-AIR Rollback Autodesk Material Library 2012 Succeeded 2012/6/1:17:45:33 Manfredi MANFREDI-AIR Rollback FaroSDK Succeeded 2012/6/1:17:45:33 Manfredi MANFREDI-AIR Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2012/6/1:17:45:33 Manfredi MANFREDI-AIR Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619
Can you please help me? I think that I should do something with .NET Framework.
Re: Installati on problem - Installati on aborted, Result=161 9
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensi
Good Luck!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Installati on problem - Installati on aborted, Result=161 9
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the answer. I spent my day tring to unistall and install again all the C++ and similar Microsoft packages to install Autocad. I unistalled all the stuff like .NET FrameWork, C++, languages pack, everything. I have also done more than one reboot. The only result I got is that now my copy of MatLab is now not working.
I tried to read your blog and the forum discussion but I found no useful tip for my needs.
This is the last log that I got a few minutes ago after antoher installation fail:
2012/6/1:19:37:14 Manfredi MANFREDI-AIR === Setup started on MANFREDI-AIR by Manfredi === 2012/6/1:19:37:14 Manfredi MANFREDI-AIR Launch 2012/6/1:19:37:20 Manfredi MANFREDI-AIR === Setup ended === 2012/6/1:19:37:15 Manfredi MANFREDI-AIR === Setup started on MANFREDI-AIR by Manfredi === 2012/6/1:19:37:15 Manfredi MANFREDI-AIR Launch 2012/6/1:19:37:20 Manfredi MANFREDI-AIR PageOpen LaunchDialog 2012/6/1:19:37:33 Manfredi MANFREDI-AIR PageOpen LicenseDialog 2012/6/1:19:37:36 Manfredi MANFREDI-AIR PageOpen ProductInfoDialog 2012/6/1:19:38:02 Manfredi MANFREDI-AIR PageOpen ProductSelectionDialog2 2012/6/1:19:38:05 Manfredi MANFREDI-AIR PageOpen FullProgressDialog 2012/6/1:19:38:05 Manfredi MANFREDI-AIR Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x6 4.exe /q 2012/6/1:19:42:01 Manfredi MANFREDI-AIR Install .NET Framework Runtime 4.0 Succeeded 2012/6/1:19:42:01 Manfredi MANFREDI-AIR Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdPart y\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_ x64_1040.exe /q 2012/6/1:19:42:41 Manfredi MANFREDI-AIR Install .NET Framework Runtime 4.0 Language Pack Succeeded 2012/6/1:19:42:41 Manfredi MANFREDI-AIR Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdPart y\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2012/6/1:19:42:47 Manfredi MANFREDI-AIR Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2012/6/1:19:42:47 Manfredi MANFREDI-AIR Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdPart y\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2012/6/1:19:42:52 Manfredi MANFREDI-AIR Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2012/6/1:19:42:52 Manfredi MANFREDI-AIR Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdPart y\DirectX\DXSETUP.exe /silent 2012/6/1:19:43:08 Manfredi MANFREDI-AIR Install DirectX Runtime Succeeded 2012/6/1:19:43:08 Manfredi MANFREDI-AIR Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian _Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/6/1:19:43:12 Manfredi MANFREDI-AIR Install FaroSDK Succeeded 2012/6/1:19:43:12 Manfredi MANFREDI-AIR Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian _Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/6/1:19:43:22 Manfredi MANFREDI-AIR Install Autodesk Material Library 2012 Succeeded 2012/6/1:19:43:22 Manfredi MANFREDI-AIR Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_Italian _Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/6/1:19:43:49 Manfredi MANFREDI-AIR Install Autodesk Material Library 2012 - Low Resolution Succeeded 2012/6/1:19:43:49 Manfredi MANFREDI-AIR Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_Italian_Win_64bit\3rdPart y\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v R:\Temp\vcredist_x86_2005.log"" " 2012/6/1:19:43:49 Manfredi MANFREDI-AIR Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2012/6/1:19:44:05 Manfredi MANFREDI-AIR Rollback Autodesk Material Library 2012 - Low Resolution Succeeded 2012/6/1:19:44:20 Manfredi MANFREDI-AIR Rollback Autodesk Material Library 2012 Succeeded 2012/6/1:19:44:21 Manfredi MANFREDI-AIR Rollback FaroSDK Succeeded 2012/6/1:19:44:21 Manfredi MANFREDI-AIR Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2012/6/1:19:44:21 Manfredi MANFREDI-AIR Rollback .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1619 2012/6/1:19:44:21 Manfredi MANFREDI-AIR Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
I would really like to have some help, thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Same failure. Make sure that there are no Microsoft Visual C++ Redistributable versions in your Add/Remove Programs in Control Panel.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello there,
thank you for responding to this thread. I am having a similar problem only it reads "installation aborted, Result=1603". Do you have any suggestions? The entire transcript is provided below. I greately appreciate the help that you've already given the forum.
2012/10/11:05:18:11 LucianNov LUCIANNOV-PC === Setup started on LUCIANNOV-PC by LucianNov === 2012/10/11:05:18:11 LucianNov LUCIANNOV-PC Launch 2012/10/11:05:18:20 LucianNov LUCIANNOV-PC === Setup ended ===
2012/10/11:05:18:11 LucianNov LUCIANNOV-PC === Setup started on LUCIANNOV-PC by LucianNov === 2012/10/11:05:18:11 LucianNov LUCIANNOV-PC Launch 2012/10/11:05:18:15 LucianNov LUCIANNOV-PC Invento
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Failing for the same reason as the original post.
Good Luck!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
2012/12/7:23:16:05 -bhey- NHAY-HP === Setup started on NHAY-HP by -bhey- ===
2012/12/7:23:16:05 -bhey- NHAY-HP Launch
2012/12/7:23:17:44 -bhey- NHAY-HP === Setup ended ===
2012/12/7:23:16:08 -bhey- NHAY-HP === Setup started on NHAY-HP by -bhey- ===
2012/12/7:23:16:08 -bhey- NHAY-HP Launch
2012/12/7:23:17:52 -bhey- NHAY-HP PageOpen LaunchDialog
2012/12/7:23:20:36 -bhey- NHAY-HP PageOpen LicenseDialog
2012/12/7:23:21:56 -bhey- NHAY-HP PageOpen ProductInfoDialog
2012/12/7:23:25:38 -bhey- NHAY-HP PageOpen ProductSelectionDialog2
2012/12/7:23:25:48 -bhey- NHAY-HP PageOpen FullProgressDialog
2012/12/7:23:25:49 -bhey- NHAY-HP Installing DirectX Runtime: C:\Autodesk\AutoCAD_Architecture_2012_English_Win_
2012/12/7:23:27:55 -bhey- NHAY-HP Install DirectX Runtime Succeeded
2012/12/7:23:27:55 -bhey- NHAY-HP Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture
2012/12/7:23:28:30 -bhey- NHAY-HP Install FaroSDK Succeeded
2012/12/7:23:28:30 -bhey- NHAY-HP Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture
2012/12/7:23:30:12 -bhey- NHAY-HP Install Autodesk Material Library 2012 Succeeded
2012/12/7:23:30:13 -bhey- NHAY-HP Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture
2012/12/7:23:32:43 -bhey- NHAY-HP Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/12/7:23:32:43 -bhey- NHAY-HP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_Architecture
2012/12/7:23:33:41 -bhey- NHAY-HP Install Autodesk Content Service Succeeded
2012/12/7:23:33:51 -bhey- NHAY-HP Installing AutoCAD® Architecture 2012: TRANSFORMS="C:\Autodesk\AutoCAD_Architecture_2012_
2012/12/7:23:34:09 -bhey- NHAY-HP Install AutoCAD® Architecture 2012 Failed Installation aborted, Result=1603
2012/12/7:23:35:03 -bhey- NHAY-HP Rollback Autodesk Content Service Succeeded
2012/12/7:23:37:04 -bhey- NHAY-HP Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/12/7:23:38:37 -bhey- NHAY-HP Rollback Autodesk Material Library 2012 Succeeded
2012/12/7:23:39:18 -bhey- NHAY-HP Rollback FaroSDK Succeeded
2012/12/7:23:39:20 -bhey- NHAY-HP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
ehto po sakin...ndi ko lam kung bakit...phelp nman po...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If uninstalling the C++ redistributables did not help, we need to take a different look at the machine. Have you tried to install via a different user account? This could be a permissions based issue. It would be good try another account on the system.
Also, if you look in the folders of the installer, you can find the c++ installers that are trying to be installed. You can manually try to install these as well. Just double-click on the C++ installed. Installing these prior to the main install may help.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
